[rusEfi] Mitsubishi 4G63 and 4G92 (#6)
Re: Mitsubishi 4G63 and 4G92 (#6)
A critical issue was just reported: https://sourceforge.net/p/rusefi/tickets/96/ Please do not run the engine before this gets fixed!
- Tambralinga
- donator
I need to fix right?
rpm 200
set_global_trigger_offset_angle 60
It will make it easier to start engine?
set_global_trigger_offset_angle >> I want to know what it is?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
No-no-no-no.
YES, you need new firmware version
NO, you do not need to apply these settings - these settings are just a way to TEST the fix, they have nothing to do with the fix itself.
- Tambralinga
- donator
The problem now is very difficult to start the engine.
original signal ECU
Rusefi signal
yellow = injection1
green= spark1
How to fix ?
original signal ECU
Rusefi signal
yellow = injection1
green= spark1
How to fix ?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
The yellow one - do we want more fuel or less fuel? Anyway please try http://rusefi.com/wiki/index.php?title=Manual:Software:Fuel_Control#Fuel_control_during_cranking
Green - spark - this one is more strange. I wonder if your spark signal is inverted from normal? Can you check voltage on the spark while while key is in 'ignition on' position and the engine is stopped? I want to be sure that the same voltage happens there with stock ECU and rusEfi. Anyway, that would be http://rusefi.com/wiki/index.php?title=Manual:Software:Ignition_Control#Timing_control_during_cranking
PS: can you please email me your mitsubishi.cpp if you made any changes, and post or email your 'showconfig' output?
- Tambralinga
- donator
Problems can not save config.
set_cranking_rpm 400
set_cranking_charge_angle 75
set_cranking_timing_angle 695
set_cranking_fuel_min 20 0
set_cranking_fuel_max 20 90
The config for mitsubishi
If off, then turn it back to the original value.
2014-10-10 14_38: EngineState: fixedModeTiming: 50
2014-10-10 14_38: EngineState: ignitionOffset=0.00000
2014-10-10 14_38: EngineState: injectionOffset=0.00000/enabled=Yes
2014-10-10 14_38: EngineState: map_avg=Yes/mil=Yes/fp=Yes/ts=Yes/wa=Yes/it=Yes/fastAdc=No
2014-10-10 14_38: EngineState: crankingChargeAngle=75.00000
2014-10-10 14_38: EngineState: crankingTimingAngle=695.00000
2014-10-10 14_38: EngineState: globalTriggerAngleOffset=114.00000
2014-10-10 14_38: EngineState: crankingRpm: 400 Code: Select all
2014-10-10 14_51: EngineState: cranking fuel 20.00000ms @ 20.00000C
2014-10-10 14_51: EngineState: cranking fuel 20.00000ms @ 90.00000C
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
writeconfig command would save the config
- Tambralinga
- donator
There is a problem with TS cranking fuel set max no more than 20ms.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
fixed. You would need fresh firmware to use with the latest TS project, or you can simply edit your project in your existing configuration - you would need to change '20' to '200' in the CrankingMaxTempPW lineTambralinga wrote:TS cranking fuel set max no more than 20ms.
- Tambralinga
- donator
idle speed control for mitsubishi have 6 pin 2 coil
Can be used with rusefi?
I do not know how to use it.
Part Number: MD628054 and MD614568
http://www.lancerregister.com/faq_f22.php
http://www.ebay.it/itm/Mitsubishi-FTO-Lancer-Evo-1-2-3-Galant-Idle-Speed-Control-Stepper-Motor-/271098280490
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
What pins have continuity? How many ohms does it read between pins 1-2, then 2-3, then 1-3. That's with 1 on the left and 3 on the right in the above picture. Is this spring loaded? For example, it might be coil 1 = move CW, and coil 2 = move CCW, then no signal means stay still. Also do you have a functional OEM system that uses this setup? If so we can sniff to see what's happening.
- Tambralinga
- donator
kb1gtt wrote:What pins have continuity? How many ohms does it read between pins 1-2, then 2-3, then 1-3. That's with 1 on the left and 3 on the right in the above picture. Is this spring loaded? For example, it might be coil 1 = move CW, and coil 2 = move CCW, then no signal means stay still. Also do you have a functional OEM system that uses this setup? If so we can sniff to see what's happening.
pin 1-2 ,2-3,4-5,5-6 = 33 ohm
How to connect to rusefi?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
At this point this type of idle valves are not supportedTambralinga wrote:How to connect to rusefi?
same stepper motor type?
http://www.msextra.com/forums/viewtopic.php?f=101&t=26900
you mean to say solenoid type valves don't work either?
The hardware valve control works for at least a year already, valve control logic is probably fine - but since no one is driving with rusEfi it's hard to tellpuff wrote:you mean to say solenoid type valves don't work either?
- rus084
maybe for first time you will try use ignition's idling?
Are pins 1-3 = 66 ohms and 4 - 6 = 66 ohms?
I have had a hardware plan for supporting steppers. I'll see if russian is on board with my plan. I think we'll have stepper support shortly. Can you take these ohm readings and let me know if they are 66 ohms?
got l293d(if i am not mistaken) - could be driven directly off 3.3v from discovery.
- Tambralinga
- donator
Yes 66 ohm.kb1gtt wrote:Are pins 1-3 = 66 ohms and 4 - 6 = 66 ohms?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
- Tambralinga
- donator
Firmware update 18-11-2014( set_engine_type 16) connect to TS led red show.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
How is it after reboot? There is a known issue with crash on config write - https://sourceforge.net/p/rusefi/tickets/114/ - restart is the current work-around.Tambralinga wrote:Firmware update 18-11-2014( set_engine_type 16) connect to TS led red show.
What's on the LCD screen?
- Tambralinga
- donator
I try to reflash default ford aspine connect to TS led red show.russian wrote:How is it after reboot? There is a known issue with crash on config write - https://sourceforge.net/p/rusefi/tickets/114/ - restart is the current work-around.Tambralinga wrote:Firmware update 18-11-2014( set_engine_type 16) connect to TS led red show.
If disconect TS and reboot led red not show.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
Are you using latest rusefi.ini file? Let me try all this at home later today and we would need to try it via teamviewer maybe.Tambralinga wrote:I try to reflash default ford aspine connect to TS led red show.
- Tambralinga
- donator
Yes latest rusefi.ini.russian wrote:Are you using latest rusefi.ini file? Let me try all this at home later today and we would need to try it via teamviewer maybe.Tambralinga wrote:I try to reflash default ford aspine connect to TS led red show.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
I do see the red LED when I connect with TS
The error message is not displayed properly - I will go downstairs & see if I see it on the LCD screen. All I get in console is
"firmware error: ," - no idea what is this comma. Does anyone want to set GDB and set a breakpoint @ and tell me the error message pretty please?
void firmwareError(const char *fmt, ...)Very limited telepathic abilities - please post logs & tunes where appropriate - http://rusefi.com/s/questions
- Tambralinga
- donator
Yes, dev_console show firmware error only.russian wrote:I do see the red LED when I connect with TS
"firmware error: ," - no idea what is this comma. Does anyone want to set GDB and set a breakpoint @and tell me the error message pretty please?Code: Select all
I do not have it broken lcd.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
This bug is now fixed. Give it 20 minutes to build and download version 5449 it should work.Tambralinga wrote:Firmware update 18-11-2014( set_engine_type 16) connect to TS led red show.
- Tambralinga
- donator
New firmware 5449 ok.russian wrote:This bug is now fixed. Give it 20 minutes to build and download version 5449 it should work.Tambralinga wrote:Firmware update 18-11-2014( set_engine_type 16) connect to TS led red show.
What pin use for fan on Board Frankenso ?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
