[help needed] UK Mazda MX5 miata NB 1.8'99 - Future Turbo project r0.5 #38
Re: UK Mazda MX5 miata NB 1.8'99 - Future Turbo project r0.5
nice to have a scope at hand to troubleshoot that sort of stuff
- RadMx5
Yeah, I must say it was my best investmentnice to have a scope at hand to troubleshoot that sort of stuff
I've changed the crank pull-up resistor (R290) from 1k to 2.7k and now it revs higher
The frequency goes now above 400Hz.
[video]https://www.youtube.com/watch?v=EiZFR9T0t_Q[/video]
[video]https://www.youtube.com/watch?v=mkljPQDqG5Q[/video]
So I can say the problem is almost solved!
Now I need a wide band. I think there is no point doing anything more when I don't know whether it runs rich or lean. The stock narrow band doesn't seem to show real values in TS. The max value I have seen on the gauge was 12 and min was 10.
...and it would be nice to have a the MIL lamp working
- andreika
- donator
You could try the latest rusEFI build with narrowband support using "Narrow to Wideband approximation".RadMx5 wrote:The stock narrow band doesn't seem to show real values in TS.
In your separate ground , what gauge wire did you use, and how long is that wire?
- RadMx5
Oh I didn't know about that andreika. Ill try it out
kb1gtt - from memory I think it was around 16gauge and about 2 meter. I have a spare reel of this wire so used it.
- andreika
- donator
You might try something like this:RadMx5 wrote:Oh I didn't know about that andreika. Ill try it out![]()
According to this on-line calculator, I would expect about a 0.2V drop from this 16AWG wire.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=13.17&voltage=12&phase=dc&noofconductor=1&distance=2&distanceunit=meters&eres=4&x=79&y=10
Even 14 AWG is about 0.13V of drop. Don't forget connections and corrosion can also add voltage drops.
NBytevenom
Connections as in adding more grounds around the car, or more things on the circuit? Just curious because I've added a couple ground wire from my engine to my chassis.kb1gtt wrote:According to this on-line calculator, I would expect about a 0.2V drop from this 16AWG wire.
Connector like pin and socket, ring terminals or flat Spade. Those also as voltage drop.
- RadMx5
andreika - I tried to use the narrow to wideband approximation but it didn't really make any difference and I was unable to type exactly the same values as you.
I have also tried replacing the R290 with a 5K resistor and it seems to be just a bit better, but not perfect. I didn't scope the signal with the 5K resistor yet. But it revs better. Occasionally I get a trigger error message in the Tuner Studio around 7K RPM.
About the ground volt drop - I'll try adding the thickest wire I can get
direct from the battery to the rusEFI, and will show you the results if it makes any difference.
- andreika
- donator
This ain't gonna work, you also need to set the EGO type:RadMx5 wrote:andreika - I tried to use the narrow to wideband approximation but it didn't really make any difference
- RadMx5
Ok,thanks I'll try it out. I had to download the latest rusefi_bundle to see these new options.
It would be very useful if we could have a big download button somewhere on the rusefi.com main page with the latest rusefi_budle. So any person who visits the website easily sees a big DOWNLOAD button with the latest changes. What you think? would it be possible?
I think the theory was that some day there will be stable releases, which include tested features. Then the bundles would be for experimental changes.
How about now? https://rusefi.comRadMx5 wrote:It would be very useful if we could have a big download button somewhere on the rusefi.com main page with the latest rusefi_budle. So any person who visits the website easily sees a big DOWNLOAD button with the latest changes. What you think? would it be possible?
Not sexy ...russian wrote:How about now? https://rusefi.comRadMx5 wrote:It would be very useful if we could have a big download button somewhere on the rusefi.com main page with the latest rusefi_budle. So any person who visits the website easily sees a big DOWNLOAD button with the latest changes. What you think? would it be possible?
Maybe put on side ...
- RadMx5
Yes, it's a lot better and easier now for me, but I think it could be more visible for new people. I have quickly drawn something
A date of publication would be useful, so people can check just by going on the rusefi.com whether they have the latest bundle or not.
And russian if you don't mind adding some information about what was changed/added?
Therefore everything would be in one place nice, clear and easy to access for people. Anyone would know what was changed, and could test the new features without searching the forum for new software changes.
What you think? Does it make sense?
Let's continue this discussion at https://rusefi.com//forum/viewtopic.php?f=13&t=1293RadMx5 wrote:A date of publication would be useful, so people can check just by going on the rusefi.com whether they have the latest bundle or not.
- RadMx5
So I had a little chance to play with the narrowband approximation and as you can probably tell it is not easy to tune with it... it seems to work. I think it goes from reach to lean as it should do, but it is not easy to read the stoichiometric mixture from it. Maybe I'll record a video showing how it behaves.
But to be honest I'm still waiting to get the wideband. I've got some questions:
1. VE table - when I increase the values does it practically mean I increase the amount of fuel injected into the engine?
2. The best way to find injector dead time?
3. My VE table is filled with a value of 80. When I decrease the value to for example 45 it is still idling, but less than 45 engine stops. Somewhere online I saw that usually, the VE tables start at 25 and then go up to around 120, it's a bit confusing...
4. I think I have purple injectors (hard to see without removing the intake manifold) regarding this: http://miataturbo.wikidot.com/fuel-injectors
they are 265cc, when I change the injector flow in tuner studio from original 200cc to 265cc then the VE value must be even bigger than 80 to keep the engine idling. Should it not be the opposite way, when injector flow is bigger the VE value should be smaller? I'm a bit confused with this as well...
5. Knock sensor circuit I'm not using it yet but is there actually any point of using it? is there a way of retarding the spark timing when knock detected or is it working at the moment just as a knock indicator?
6. What wideband sensor do you recommend for the 1.8 miata and rusEFI? Should I bother buying the controlling gauge as well?
I think this is all I want to ask for now
Thanks!
I thought that VE is a function of your camshaft, your inlet and your exhaust system. but probably yes, the higher the VE value, the more air your engine sucks in and the more fuel you want there (imho)
Knock sensing in rusEfi is not working and not finished.RadMx5 wrote:5. Knock sensor circuit I'm not using it yet but is there actually any point of using it? is there a way of retarding the spark timing when knock detected or is it working at the moment just as a knock indicator?
I would recommend some innovate wideband with a gauge - the gauge and the controller are often sharing the same body these days.
Yes. The way that speed-density fuel injection works is that the computer estimates the density of air in the intake, then the VE (volumetric efficiency) gives what percentage of that density makes it in to the cylinder through the open intake valve. An ideal engine would have 100% VE everywhere, but due to acoustics and the valve being open for a limited period of time, it varies with engine load and speed.RadMx5 wrote: 1. VE table - when I increase the values does it practically mean I increase the amount of fuel injected into the engine?
Unless you have the data for your injectors, you have two options.RadMx5 wrote: 2. The best way to find injector dead time?
First, you can guess. This does work, but it isn't great. A guess is plenty to get the engine running, and is enough to have a perfectly drivable car.
The second option is to rig up a test bench to test amount of injected fuel vs. injection pulse width.
Around 40-60% sounds about right for VE at idle. Here's what the VE table for my Volvo looks like. Keep in mind that it's a completely different engine (and has a turbo), but the general shape is common to most engines. As a rule of thumb the peak VE should be at or near peak torque on the engine, so for me, that's around 3500-4000 RPM.RadMx5 wrote: 3. My VE table is filled with a value of 80. When I decrease the value to for example 45 it is still idling, but less than 45 engine stops. Somewhere online I saw that usually, the VE tables start at 25 and then go up to around 120, it's a bit confusing...
As for the injector flow doing something that doesn't make sense, that's strange. It sounds like something in the config isn't quite right. Are you willing to share your .msq tune file, and a datalog of the engine running?
Would https://rusefi.com/forum/viewtopic.php?f=5&t=1085 be a 3rd option?mck1117 wrote: Unless you have the data for your injectors, you have two options.
ZHoob2004
I don't have any experience with them, but I've seen a number of megasquirt users recommending 14Point7 Wideband controllers and gaugesRadMx5 wrote:6. What wideband sensor do you recommend for the 1.8 miata and rusEFI? Should I bother buying the controlling gauge as well?
Their base offering is a controller and sensor with no display, perfect for integrating into an EFI system.
https://www.14point7.com/products/spartan-lambda-controller-2
http://forums.hybridz.org/topic/128106-14point7-wideband-o2-controllers-megaspartan-and-idash/
NO AFFILIATION - I CAME ACROSS THEM ON HYBRIDZ (link above) AND THOUGHT THEY LOOK NEAT
- andreika
- donator
There's one more important point: voltages must be arranged ascending, otherwise it won't work. Please correct your table (turn it upside down).RadMx5 wrote:andreika - I tried to use the narrow to wideband approximation but it didn't really make any difference and I was unable to type exactly the same values as you.
Reminds me of https://github.com/rusefi/rusefi/issues/440 - anyone willing to implement?
- RadMx5
Thanks for all your replies!
I haven't done anything on this project since my last post. I was waiting for some bits to arrive
Finally I got the Innovate controller with a Bosch wideband and a boost gauge (getting ready for the BOOST). Just need to mount them somewhere in the car and start some experiments.
- RadMx5
I have added a thick ground wire from the battery to the ECU but it doesn't improve the CRANK trigger signal... So I'm still getting the trigger problem above 6500 RPM. For now, I just limit the RPM in TS to 6500
Small update - gauges fitted
Beautiful gauges placement!
I hope that with our simple Miata trigger 6500 is not the firmware performance limit. The way I am testing performance is with two discovery boards - I am using one to generate signal on PD1 & PD2 pins with disabled ignition and injection, and the other one as signal consumer. Sometimes with a cheap logic analyzer in between.
Do you have a log of the 6500 RPM issue? I wonder if high RPM jitter could be causing problems. I expect that this jitter would not exist on @'s simulation.
I wonder if the simulation could add some jitter and then see if it generates the same issues with some controllable amount of jitter. Could the simulation STM be programmed such that once every crank pulse, it generates a random number, then multiples that number with a constant, then adds or removes that number from the time for the next cam / crank event? Then with TS or the console, you can increase or decrease the constant to increase or decrease the amount of jitter. Is that a possible method to check the effects of jitter on the crank decoder?
I bet we were close to 7000rpm during the races pretty often - see https://svn.code.sf.net/p/rusefi/code/misc/logs/1991_miata_hunchback/
Do not remember if there were trigger errors there but these logs could be a reference point.
