W7
Yes I installed the drivers with the console
microRusEfi connection to Tuner Studio
Re: microRusEfi connection to Tuner Studio
please try installing https://github.com/rusefi/rusefi_external_utils/raw/master/DFU_mode/DfuSe_Demo_V3.0.6_Setup.exe
manually maybe this would get drivers installed properly?
I found a way to install the missing driver. I installed it manually from the device manager.
You have to give the path : C:\Program Files (x86)\STMicroelectronics\Software\DfuSe v3.0.6\Bin\Driver\Win7
Maybe You have so many old USB connections ...
Delete what you not used in Devices manager/universal serial bus controller.
And? Did you get to update firmware? is connection reliable now?
is your problem solved?
The firmware update was successful.
Now the connection with TS is stable.
I just asked a question on SLACK about the blinking red/green Indicator in the Bottom right corner of the TS screen.
It seems that the problem is the automatic install of the STM32 bootloader does not work.
I must have missed it
My red/green indicator in the bottom right is not steady green. It blinks red/green. So I asked if it is normal. Since then I made some test changes with TS and it burns correctly in mre so I think it is normal.
In your new video about programming you introduce the need to push the program button.
I didn't knew it when I program mine so I haven't done it but it worked!
In my video I was doing initial first time programming which is also emergency-things-are-broken programming, first time even from the factory button usage is required, that's "Manual DFU"
Your programming is the good-case-normal-user programming "Auto DFU" it does not require the button.
Thanks useful information !
