If anyone has an issue accessing JDY-31 using putty.
You can try Arduino IDE serial monitor:
Also tried to use Serial Port Utility and it works as well.
Link to windows software: https://wiki.wit-motion.com/english/lib/exe/fetch.php?media=serial_port_utility.rar
Spec and AT command sheet can be found:
http://myosuploads3.banggood.com/products/20190129/20190129043725SKUA87502.pdf
[help needed] HOWTO use Bluetooth module
opelpanfan
- Github Username: opelpanfan
- Slack: Ben
Re: HOWTO use Bluetooth module
Weird, how come?! Wonder which settings are we not setting in Putty to not have it working
opelpanfan
- Slack: Ben
Maybe default Flow control?
Putty defaults to XON/XOFF
Wow that Serial Port Utility has done the trick for me! Got "AT+VERSION" response from my JDY-33
It's a small world. It has Beken BK3231S chip see https://rusefi.com/forum/viewtopic.php?f=13&t=1999 where JDY was not mentionedopelpanfan wrote: ↑Thu Mar 03, 2022 12:25 pmIf anyone has an issue accessing JDY-31 using putty.
And JDY-33 sometimes says BK3432 https://www.bekencorp.com/en/goods/detail/cid/17.html
Anyway there is also JDY-40 based on BK2461
And then there is https://www.elektroda.com/rtvforum/topic3758492.html calling all these clones of NRF24L01 ?
jlowens76
- Github Username: interbiznw
it has to do with the end of line characters, the correct ones aren't sent with the apps that don't work, you can play with them and see which specific that work by using arduino serial monitor and changing them, seeing which work and which dont then trying that in the other apps.
I used arduino serial monitor for a bit till i got tired of that and started using RealTerm
lets you specify if your sending numbers/vs ascii, pick EOL characters, and \n
scfrontier
- Github Username: scfrontier
I just fixed a bug relating to the initialization of our bluetooth modules (using RUSEFI console commands). When a baud rate change was requested, we were trying to connect at the new baud rate instead of the current "working" baud rate. This was reporting back to the console as a NAME change failure. Now we connect at the working baud rate - then make changes - reset - find working baud - repeat...
Hope this helps.
Hope this helps.
SC
Current status with a questionable chip:
now sure if anything is broken here, is name officially broken due to https://github.com/rusefi/rusefi/issues/5918?
2024-06-26_12_13_28_844: EngineState: confirmation_bluetooth_jdy 115200 alphax 1234:32
2024-06-26_12_13_29_191: EngineState: *** Bluetooth module setup procedure ***
2024-06-26_12_13_32_255: EngineState: Restarting at 115200
2024-06-26_12_13_32_256: EngineState: sending AT
2024-06-26_12_13_34_781: EngineState: Timeout waiting for BT reply after 0 byte(s)
2024-06-26_12_13_34_782: EngineState: sending AT+DISC
2024-06-26_12_13_37_222: EngineState: Timeout waiting for BT reply after 0 byte(s)
2024-06-26_12_13_37_222: EngineState: Restarting at 9600
2024-06-26_12_13_37_222: EngineState: sending AT
2024-06-26_12_13_37_333: EngineState: Received 5 +OK
2024-06-26_12_13_37_333: EngineState: sending AT+VERSION
2024-06-26_12_13_37_334: EngineState: Received 41 +VERSION=JDY-33-V1.1,Bluetooth V3.0+BLE
2024-06-26_12_13_37_334: EngineState: sending AT+BAUD
2024-06-26_12_13_37_335: EngineState: Received 9 +BAUD=4
2024-06-26_12_13_37_335: EngineState: sending AT+TYPE
2024-06-26_12_13_37_445: EngineState: Received 9 +TYPE=1
2024-06-26_12_13_37_446: EngineState: sending AT+PIN
2024-06-26_12_13_37_446: EngineState: Received 11 +PIN=1234
2024-06-26_12_13_37_446: EngineState: sending AT+LADDR
2024-06-26_12_13_37_446: EngineState: Received 21 +LADDR=1FD9C6BB0E40
2024-06-26_12_13_37_447: EngineState: sending AT+STAT
2024-06-26_12_13_37_447: EngineState: Received 10 +STAT=00
2024-06-26_12_13_37_448: EngineState: sending AT+DEFAULT
2024-06-26_12_13_37_557: EngineState: Received 5 +OK
2024-06-26_12_13_37_557: EngineState: sending AT+ENLOG0
2024-06-26_12_13_37_557: EngineState: sending AT+TYPE0
2024-06-26_12_13_37_558: EngineState: Received 5 +OK
2024-06-26_12_13_37_558: EngineState: sending AT+NAMEalphax
2024-06-26_12_13_37_669: EngineState: Received 7 +O+OK
2024-06-26_12_13_37_669: EngineState: FAIL! Command AT+NAMEalphax failed
AT+NAME=Param1 - did you miss '='?
