Alternator field control circuit
Re: Alternator voltage control
As noted above and here http://rusefi.com/forum/viewtopic.php?f=4&t=286&start=55 This is the list I think we should consider for a thermally protected P-MOSFET, apparently called a Hight Side Switch (HSS) by ST.
For above 1A I get concerned with using SO-8 packages as the heat will be hard to get out of the chip and it will be hard to uphold the rated amp of that chip. Much like the hi/low is only able to do 1/8 amps when it's technically rated for 2A. The thermal properties become important when you go higher in current.
$4.20 2ch http://octopart.com/vnd5e025aktr-e-stmicroelectronics-17417297 also has eval board http://octopart.com/ev-vnd5e025ak-stmicroelectronics-25737927 for $20
$3.25 2ch http://octopart.com/vnd7020ajtr-e-stmicroelectronics-30039249
$3.18 2ch http://octopart.com/vnd5e025mktr-e-stmicroelectronics-18186948
$3.95 2ch http://octopart.com/vnd5e025bktr-e-stmicroelectronics-21218838
$2.38 1ch http://octopart.com/vn7020ajtr-e-stmicroelectronics-31115209
$2.99 1ch http://octopart.com/vnd7030ajtr-e-stmicroelectronics-30039251
My favorite is VND5E025AK-E, as it has 3 potential drop in replacements so it should be good for long term and it has an off the shelf eval board so faster development cycle. Then my next runner up is VND7020AJ-E because it's cheapest per channel.
$/1	  PT#	        ch  volts amps mohm Vmax '$/ch	pkg           notes
$3.25	VND7020AJ-E	 2	28	63	22	40	$1.63	PowerSSO-16
$2.38	VN7020AJ-E	  1	28	63	20	40	$2.38	PowerSSO-16
$2.99	VND703AJTR-E	1	28	56	31	40	$2.99	PowerSSO-16
$3.95	VND5E025BK-E	2	28	60	25	41	$1.98	PowerSSO-24
$4.20	VND5E025AK-E	2	28	60	25	41	$2.10	PowerSSO-24	Eval $20
$4.20	VND5E025MK-E	2	28	60	25	41	$2.10	PowerSSO-24
kb1gtt wrote:My favorite is VND5E025AK-E, as it has 3 potential drop in replacements so it should be good for long term
You are the boss. Need a board :)
2nd channel would be useful if someone needs VTEC with constant 2A current.
russian wrote:You are the boss. Need a board :)
Image just placed an order
PowerSSO-24 board has arrived. Need pin#1 marker and the larger heatsink vias would be easier to work with, but the main thing is that everything aligns right.
I do not have the diodes yet, how essensial are they to try the board?
The diode is critical, needed for fly-back topology.
Added reminder in knownissues.txt about the pin1 indicator.
Looks like the hardware side of Dodge Neon high-side field control wire is taken care of now, next step the software.
Check the video - notice how voltage changes bit by bit while I am increasing PWM duty cycle, and then it suddenly runs away. Looks like PID would be needed?
Very nice, very nice. In terms of software you probably want to filter the analog signals some, to smooth out that needle. The PID will not like the noise either.
How hot did the chip get?
kb1gtt wrote:How hot did the chip get?
I think it was slightly warmer then the rest of the engine bay in that area.
Now configurable via Tuner Studio
Great and thanks for that offset thing. One request, can you put a note on it some where that notes output % duty = Pterm + Iterm + Dterm + offset%
Hmmmm, it might also be good to also post the general algo some where on that screen. Such that those of us who want to know the details of what kind of PID we are dealing with (mostly how the I term is handled) it would help show that with out requiring jumping into the code.
As a note to others who might come across this thread. The offset is for a kind of manual tuning. For example, if the P, I and D set to 0, the output will equal the offset% which means manual control. You can then manually adjust the output duty until you reach 14V. At this point you know what the PID loop should be adjusting too, which can be handy when tuning. AKA if you know where you should be you'll have some insight to see if you are getting there correctly.
gptech2444
Re: Alternator field control circuit
Post by gptech2444 »
What was the end result of the alternator control?
I ended up getting a westfield alternator board for my 2003 MX5.
It just works :)
gptech2444
russian wrote:
Wed Apr 11, 2018 12:05 am
It just works :)
Ok, but where and how do I get hold of this circuit? And where is it documented to set it up?
edit
I've ordered the IC from Mouser, was $4.73aud
gptech2444
Is it as simple as this? Where do you place the diode for flyback?
Is not miata alternator controlled by just logic level pwm signal? I believe my 2001 miata controls the alternator with only frankenso as is.
On dodge neon yes we used that large mosfet with the small addon board. I need to document better when i get home on Saturday
gptech2444
russian wrote:
Wed Apr 11, 2018 11:34 am
Yes, you are correct, I thought we still needed some external chip before the alternator.
https://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_1999
