Now, what brought me on your project and forum. I have Citroen C5 2.0 HPi (2001) engine code: RLZ - EW10D, which is direct injection engine. The car is in good condition and I would like to make it running on LPG.
Easiest is to buy DI LPG ECU, however there are some problems. The engine burns some oil and it cracks the wideband O2 sensor. Second the cat. converter is removed (too expensive for replacement, moreover we bought some 2nd hand cat. converters that broke down soon after the replacement was made).
Also I suppose that the injectors aren't in very good shape, but I have no means to check that (my Chinese Lexia OBD reader doesn't work well, but I can give it one more chance).
The engine was probably overheated. The car service in my town repaired the cylinder head, new water pump, etc, however I suspect the mechanics in incompetence. The timing belt wasn't properly installed. A new spark plugs were to be installed, but I found that they installed the old ones. 1st cylinder's spark plug was welded and completely out of order.
However, now some parts are replaced. Visual inspection of the spark plugs doesn't show learn burning (they look in good shape). The pre-cat (wideband) O2 sensor is still not working.
The engine starts smoothly in warm weather and not so well in cold weather. Smell of rich fuel.
I would like to install LPG on this car, however I have the option to break the original gasoline injectors and probably completely destroying them while working on LPG.
Next, I wouldn't like to invest in specialized DI LPG ECU since I don't plan to replace the O2 sensor. From what I saw on youtube the fuel mixture should be very precise (when using both gasoline and LPG). Also I suppose that the high pressure fuel pump would fail after some time (common problem on these engines).
I don't plan to use the engine with lean mixtures, so my idea isn't replacing the factory ECU. However I would like to preserve the original injectors (as they're still working) and try to run the engine on LPG and if it is needed - LPG/gasoline mixture (to preserve the condition of the injectors).
So my first question is can rusEfi be used in "bifuel" mode? What I saw on the PCB is that it has probably 12 mosfet drivers so I guess that two banks of 4 mosfets can do the trick? I'm not aware of the correct waveform (power supply) of the original injectors, also the timing (I read that they're much quicker than the normal injectors). I can measure these levels with an oscilloscope.
Second question - the car has electronic throttle. I didn't search the site and the forums whether rusEfi can drive such throttle or not, so excuse my incompetence.
Third question - I would like to play with the electronics and the engine, but I would like to use the car as everyday car. Since I didn't make similar projects, I think it will be best to leave all the car electronics in place. I'm not sure if I have to make general re-wiring of the car electronics or not :-/ I'm not sure how the ECU works with the other modules in the car. If it is safe to preserve ABS, airbags and so on I would probably remove the original engine ECU, otherwise I'll have to put some "simulators" on it's wiring?
And last but not least - I'm driving VW Golf 4 on LPG. I see how the engine works and how the LPG ECU's proxy the petrol ECU. When some of the petrol/LPG components doesn't work properly a complete mess happens with the air to fuel mixture. So I would like to experiment also with rusEfi in order to have an ECU working in 2 modes for petrol and LPG, so the ECU knows each subsystem (petrol/LPG) in order to work properly in all cases.
Well.. I have much more questions, but this is in general. If I can get help and courage from you I would like to play with rusEfi.
PS: I have moderate to good skills in electornics, I'm using STM32L1xx MCU's in my work so I guess that I can probably contribute for the project.
All the best!
