I have a dev board to fiddle with, but I'm on an airplane right now, so no board.
Therefore I'm running the simulator to try out my code.
Its damn hard to read the console because a CLT unrealistic warning is shooting over and over.
I've tried messing with the sensor settings (setting MAX CLT to way above the amount it is reading), but no luck.
Console Simulator "unrealistic CLT" fix
Re: Console Simulator "unrealistic CLT" fix
set mock_clt_voltage 1.2
set mock_tps_voltage 2.1
etc
See also https://github.com/rusefi/rusefi/blob/master/firmware/controllers/settings.cpp mentions
etc
