Full features?
headsock
Full features?
Post by headsock »
Hi,
New here.
Where can I find the full feature list of what RusEfi can do? Are there other features RusEfi can do other than whats posted on https://rusefi.com//wiki/index.php?title=RusEfi:About#FEATURES
Ie.
Sequential injection/ignition
Individual injector trims (couldn't see it on tunerstudio using one of the base maps here)
Closed loop fuel (greyed out in tunerstudio)
Boost control?
Flat foot shift
Dual VVT (important, I've seen single VVT on Russians Miata)
Dual Knock (is it single knock?)
PWM maps?
Re: Full features?
Hello
I guess the easiest is to download the https://rusefi.com//build_server/rusefi_bundle.zip and create a TunerStudio project based on rusefi.ini and look around all the dialogs?
Screen shots available at https://github.com/rusefi/rusefi/tree/master/firmware/tunerstudio/docs
Sequential injection/ignition YES
Individual injector trims (couldn't see it on tunerstudio using one of the base maps here) NO
Closed loop fuel (greyed out in tunerstudio) YES
Boost control? via PWM maps
Flat foot shift NO
Dual VVT (important, I've seen single VVT on Russians Miata) two PWM maps are possible
Dual Knock (is it single knock?) KNOCK VERY UNTESTEED
PWM maps? YES, that's how VVT works
headsock
Re: Full features?
Post by headsock »
Thanks for the reply. I guess I need another PWM map. Can this be added?
With vvti, is it closed loop?
Re: Full features?
Yes VVT is closed loop.
A lot of office work and life these days, I spend very little time on firmware improvements these days :( But if you would be able to implement a chance I am available to review and merge into the primary branch.
