At the moment the bottleneck is not with RAM but with software developers availability. I am not sure when I would have time for any meaningful code contribution.
Shall we start with FSIO controlling the transistor and two injectors using different areas of the same map? This would require zero code changes.
Bi-fue / dual fuel capability?
Re: Bi-fue / dual fuel capability?
Yes please.
Just to confirm. do you need help to switch between two injectors using FSIO or do you know how to do that based on existing FSIO documentation examples? This is pretty much https://rusefi.com/wiki/index.php?title=Manual:Flexible_Logic#Case_study_.231:_shift_light
Something like this?russian wrote: ↑Sat Sep 29, 2018 3:13 pmJust to confirm. do you need help to switch between two injectors using FSIO or do you know how to do that based on existing FSIO documentation examples? This is pretty much https://rusefi.com/wiki/index.php?title=Manual:Flexible_Logic#Case_study_.231:_shift_light
set_fsio_output_frequency 3 0
set_fsio_output_pin 3 PE5
set_fsio_expression 3 "rpm > 4500"
set_fsio_output_frequency 4 0
set_fsio_output_pin 3 PE6
set_fsio_expression 3 "trottle> 50"
now i need something like this "IF PE5==1 AND PE6==1 ,PE7"
So you want something like
set_fsio_expression 3 "(rpm > 4500) and (trottle> 50)"
