[info] Vvt Mx5 Na
Vvt Mx5 Na
Hi to all i run a mx5 with ms2 actually and I don't like dealing with the ms2 hardware.... I have a vvt engine and look like I am free to do anything with rusefi. I can build any hardware outside the mcu. I can do some pcb myself. I'm looking for a stripped down brain board pcb only or populated to avoid delicate mcu soldering.I prefer avoir the already done board because I don't like useless hardware. I have some experience with smd soldering but honestly it piss me off....... All my homemade board are traditional components.
Some questions also.
Engine definition is lost only in case of firmware update? Do I need to load manually the engine definition ?
Thanks a lot for something that is powerful free and really true DIY.
Re: Vvt Mx5 Na
- tmp_15967-1509785184705-1017679846.jpg (35.13 KiB) Viewed 10803 times
- tmp_15967-DSC_0033-1683259780.JPG (2.6 MiB) Viewed 10803 times
- tmp_15967-DSC_02571356387282.JPG (1.99 MiB) Viewed 10803 times
- tmp_15967-14922838124142007169923.jpg (77.05 KiB) Viewed 10803 times
- tmp_15967-1510559868864-1519502471.jpg (37.9 KiB) Viewed 10803 times
- tmp_15967-1519681700520-1443447442.jpg (357.13 KiB) Viewed 10803 times
- tmp_15967-1523123253122676110620.jpg (578.86 KiB) Viewed 10803 times
- tmp_15967-1523123248165170053246.jpg (616.09 KiB) Viewed 10803 times
- tmp_15967-1523123261633-1554232223.jpg (641.36 KiB) Viewed 10803 times
- 2018-07-15 15.14.34.jpg (1.79 MiB) Viewed 10803 times
Re: Vvt Mx5 Na
Hope someone gonna help me little with the vvt and rusefi.
Thanks
- tmp_15967-DSC_0279204435497.JPG (1.7 MiB) Viewed 10803 times
- tmp_15967-DSC_02711512221021.JPG (1.48 MiB) Viewed 10803 times
- tmp_15967-150866576332573005409.jpg (42.23 KiB) Viewed 10803 times
Re: Vvt Mx5 Na
I am sorry i should hace responded sooner - i am stavelling now but will be back in reality in four days
Where are you with rusefi hardware at the moment?
Re: Vvt Mx5 Na
Hi thanks for your reply.
About rusefi I try to understand what exactly is rusefi.
I tried to run your simulator but on the last tunerstudio free i can't find the connection described in the wiki.
About the hardware i am still thinking what to do.
Maybe I just gonna order a demo board with rusefi already flashed to try.
I really want to improve my level with mcu programming also.
I just wish rusefi gonna stay free and open source like actually. Simple and easy to handle.
The Prometheus board look excellent but a bit complicated for diy fan. If one board is available for testing my car is ready to switch between ms2 and rusefi Prometheus.
If I can find a brainboard populated and build a tough hole hardware im happy. My feelings is really wish to do something that all people can build at home with limited material.
Frankenso and Frankenstein board ar not really matching my car. I have bmw tps. gm intake temperature sensor. 36 1 trigger 306s16 vr sensor lm1815 vr circuit. original mx5 cam sensor with home made single toot disc. Techedge wideband.
I plan to ad gm flex fuel sensor and boost solenoid.
I have two engine. A b6 that I prepare for turbo and a bp vvt.
I search cheap forged piston for the b6 turbo if someone have a good deal please share.
Thanks for all your work rusefi look excellent.
Thank you
Thank you
Re: Vvt Mx5 Na
Can I just ask you why you use that complicated hardware with opamp all the places and why you don't use a 5v mcu.
It is a special reason behind this ?
Re: Vvt Mx5 Na
Do you know a 5V 32 bit or better processor with floating point unit? At the time it was a low cost decent sized bit pump with some hardware which makes it very nice to deal with floating math.
Re: Vvt Mx5 Na
Ok sorry for my newbie reply on the post in hall sensor buffer.
My level of knowledge about mcu is not high and now I understand the proposal of opamp buffer.
If possible.... I am thinking it's better to use a more expensive mcu and do economic and simple hardware.
Let's try rusefi.
Thank you for your work.
Let's try rusefi.
Re: Vvt Mx5 Na
please post full URL of the page which shows outdated screenshots.
Re: Vvt Mx5 Na
- tmp_17659-Screenshot_2018-07-16-20-36-33-2029102280.png (250.64 KiB) Viewed 10763 times
- tmp_17659-Screenshot_2018-07-16-20-38-151397279865.png (291.25 KiB) Viewed 10763 times
Re: Vvt Mx5 Na
Do this board can be a good brainboard ?
- tmp_17659-fb04bba0446224691638424429.jpg (274.1 KiB) Viewed 10755 times
Re: Vvt Mx5 Na
This board is known to work.
https://sourceforge.net/p/rusefi/code/HEAD/tree/trunk/hardware/brain_board_STM32F407_SD_wing-it/
As well if one does not want the discovery board, they can simply populate the STM chip on the frankenso board.
If you want to design something with that board, feel free. It's one of the great things about open source.
Re: Vvt Mx5 Na
Yes sir that's what I am thinking to do.
Design something that just match my requirements with that board as brainboard. All with trough hole components and home printed pcb single or dual layer.
If I can achieve this im too much happy.
I gonna order a discovery board for try then also this violet board to see if I can do something funny.
It's only 9 dollars......
Re: Vvt Mx5 Na
https://rusefi.com/wiki/index.php?title=Manual:Software:Simulator edited to mention that TCP connector requires a registered TS.
Re: Vvt Mx5 Na
Has your stm32f4discovery showed up - did you have success connecting to it?
What is the exact URL for violet $9 board I am curious to read more about it.
- Slack: Orchardperformance
Re: Vvt Mx5 Na
It appears to be the same board they sell here:
https://www.ebay.com/itm/Open407V-D-Core407V-Development-Board-Standard-STM32F4-DISCOVERY-ARM-Cortex-M4/172740399220?var=471521948086&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D53210%26meid%3D24a63b9531f648ea861aa957e2a5c3de%26pid%3D100623%26rk%3D2%26rkt%3D6%26sd%3D172740399220%26itm%3D471521948086&_trksid=p2047675.c100623.m-1
Came across it earlier on Ebay while looking for an F407 Discovery.
Edit - Looks like a china clone, several places selling them by the look of it:
https://www.amazon.ca/STM32F4Discovery-STM32F407VGT6-Cortex-M4-32bit-Development/dp/B01M7WPYRF
