assistants for assembly PCB
This plugin was born from necessity of generating convenient BOM listing with ability to easily search for components and their placements on the pcb.
This is really useful when hand soldering your prototype and you have to find the 50 places where that 0.1uF cap should be or which of these SOP8 footprints are for the same micro.
https://hackaday.com/2018/09/04/interactive-kicad-boms-make-hand-assembly-a-breeze/
https://github.com/openscopeproject/InteractiveHtmlBom
NBytevenom
Re: assistants for assembly PCB
Post by NBytevenom »
Maybe I'll finally get around to putting my kit together now with this!
KiCad 5.0 is the only fully supported version.
Lovely, we are still on KiCad 4 I did not even know there was KiCad 5. KiCad 5.0.0 was released in July 2018
http://kicad-pcb.org/download/ OMG it's 1014MB download?! That's a bit above average size :)
Downloading...
Looks like our custom footprints are not happy?
8:37:27 PM: Alias 'ADS7843E/2K5' not found in library:
'C:\Program Files\KiCad\share\kicad\library\adc-dac.dcm'
at line 465 offset 18
8:37:27 PM: Alias 'MCP3421A0T-E/CH' not found in library:
at line 746 offset 21
8:37:27 PM: Alias 'MCP3425A0T-E/CH' not found in library:
at line 770 offset 21
8:37:27 PM: Alias 'MCP3425A1T-E/CH' not found in library:
at line 776 offset 21
8:37:27 PM: Alias 'MCP3425A2T-E/CH' not found in library:
at line 782 offset 21
8:37:27 PM: Alias 'MCP3425A3T-E/CH' not found in library:
at line 788 offset 21
8:37:27 PM: Alias 'MCP3550-50-E/MS' not found in library:
at line 830 offset 21
8:37:27 PM: Alias 'MCP3550-60-E/SN' not found in library:
at line 836 offset 21
8:37:27 PM: Alias 'MCP3551-E/MS' not found in library:
at line 842 offset 18
8:37:27 PM: Alias 'MCP3553-E/SN' not found in library:
at line 848 offset 18
8:37:27 PM: Alias 'MCP4801-E/MC' not found in library:
at line 866 offset 18
8:37:27 PM: Alias 'MCP4811-E/MC' not found in library:
at line 884 offset 18
8:37:27 PM: Alias 'MCP4821-E/MC' not found in library:
at line 902 offset 18
8:37:27 PM: Alias 'MCP4901-E/MC' not found in library:
at line 920 offset 18
8:37:27 PM: Alias 'MCP4911-E/MC' not found in library:
at line 938 offset 18
8:37:27 PM: Alias 'MCP4921-E/MC' not found in library:
at line 956 offset 18
8:37:27 PM: Alias 'MCP4921-E/MS' not found in library:
at line 962 offset 18
8:37:27 PM: Alias 'MCP4921-E/P' not found in library:
at line 968 offset 17
8:37:27 PM: Alias 'MCP4921-E/SN' not found in library:
at line 974 offset 18
8:37:27 PM: Alias 'MCP4922-E/P' not found in library:
at line 986 offset 17
8:37:27 PM: Alias 'MCP4922-E/SL' not found in library:
at line 992 offset 18
8:37:27 PM: Alias 'MCP4922-E/ST' not found in library:
at line 998 offset 18
8:37:27 PM: Alias 'XC3S200AN/FT256' not found in library:
'C:\Program Files\KiCad\share\kicad\library\xilinx.dcm'
at line 38 offset 21
8:37:27 PM: Alias 'ENC28J60-C/SS' not found in library:
'C:\Program Files\KiCad\share\kicad\library\microchip.dcm'
at line 3 offset 19
8:37:27 PM: Alias 'ENC28J60-I/ML' not found in library:
at line 9 offset 19
8:37:27 PM: Alias 'ENC28J60-I/SO' not found in library:
at line 15 offset 19
8:37:27 PM: Alias 'ENC28J60-I/SP' not found in library:
at line 21 offset 19
8:37:27 PM: Alias 'MCP2050-330-E/MQ' not found in library:
at line 39 offset 22
8:37:27 PM: Alias 'MCP2050-330-E/P' not found in library:
at line 45 offset 21
8:37:27 PM: Alias 'MCP2050-330-E/SL' not found in library:
at line 51 offset 22
8:37:27 PM: Alias 'MCP2050-500-E/MQ' not found in library:
at line 57 offset 22
8:37:27 PM: Alias 'MCP2050-500-E/P' not found in library:
at line 63 offset 21
8:37:27 PM: Alias 'MCP2050-500-E/SL' not found in library:
at line 69 offset 22
8:37:27 PM: Alias 'MCP2515-E/ST' not found in library:
at line 117 offset 18
8:37:27 PM: Alias 'MCP2515-I/ST' not found in library:
at line 123 offset 18
8:37:28 PM: Alias 'TJA1051T/3' not found in library:
'C:\stuff\rusefi\hardware\rusefi_hardware_history\frankenso_rev00.40\rusefi_lib\art-electro-ic.dcm'
at line 41 offset 16
8:37:28 PM: Alias 'MAX9926/9927' not found in library:
'C:\stuff\rusefi\hardware\rusefi_hardware_history\frankenso_rev00.40\rusefi_lib\art-electro-max.dcm'
at line 3 offset 18
Under the changes I'm excited to see
-- New 3D viewer
-- New 3D model plugin architecture
Now supports STEP and IGES viewer
STEP assembly export from STEP and IGES inputs
-- Simple math equations in some input fields
-- Table view for editing symbol fields
-- Direct update of board without need for intermediate netlist
-- Custom pad shapes
-- Improvements to the arc drawing tool
-- Improvements to the zone drawing and editing tools
I also see
-- New libraries for symbols, footprints and 3D models
-- Footprint libraries installed locally and the Github plugin is no longer the default
That is likely where the 1gig download is coming from. Those 3d models take allot of space.
