Basic / Trigger setting problem - little bit confused
darxfame
Re: Basic / Trigger setting problem - little bit confused
Post by darxfame »
JRD McLAREN wrote:
Thu Mar 14, 2019 8:00 pm
VW 1.8T 20Valve Crank ...
..and same 60/2 trigger wheel as my ...
..and many others ...
Can you send me the part number of your sensor? Maybe you can start with my settings(but no use my pin settings, i have another board)
i have crank vr sensor https://avtopasker.ru/goods/7537 and cam hall sensor. https://www.avtoall.ru/datchik_fazy_vaz_2110_2111_8v_daewoo_lanos_aenk_k-080367/
JRD McLAREN
Post by JRD McLAREN »
russian wrote:
Fri Mar 15, 2019 3:42 am
I am starting to think that you might be right here...
Part of the challenge is that I never had a 60/2 VR in my life. @ is the only 60/2 not far from me and that's why I called it VW, he has a VW :)
Let me ask @ and @ to comment on this since they both run 60/2 and they could be affected by all this. I guess they are OKish since they use "use only rising edge" at which point both shapes look the same?
Look at this picture ....
JRD McLAREN
darxfame wrote:
Fri Mar 15, 2019 4:29 am
I have many sensors, ..
Old original one but still working is BOSCH 0 261 210 030
Now I have VR from Daewoo / Chevrolet Lacetti OE: 96253542 or 25182450
My sensors works fine ... ;)
Your engine work on full sequential mode ..?? (2x360deg rotation /720deg)
or on wasted / batch mode .. ?? (1x360deg rotation) ..
.. cause I see " 4 stroke without cam sensor " . ...
Just added
rusEfi trigger configuration is the most confusing part of rusEfi configuration unfortunately.
If rusEfi does not know your exact overall trigger shape and you use composite setup with crank sensor driving RPM and single tooth cam sensor providing phase information, that's considered "4 stroke without cam with VVT". Even if you do not have VVT :(
to https://rusefi.com/wiki/index.php?title=Manual:Software:VVT
JRD McLAREN
..Wow .. OK ...
this setup in rusefi is totally differnet from all others ecu, which I have ... :)
So now I look at Abricos engine, and he has old VW 2.0 litre 8Valve engine,
and this engine has same 60-2 tr.wheel as my.. on VR sensor.
but, Thanks for advice.
JRD McLAREN wrote:
Fri Mar 15, 2019 12:41 pm
..Wow .. OK ...
I am aware of the problem but I do not have a better layout for the configuration dialog at the moment :(
JRD McLAREN
...make some "CHECKBOX" .. for CAM sensor .. maybe ..??
But, I's OK at this moment...
My engine run, and is not problem to make some tests with CAM an CRANK configurations. :)
JRD McLAREN wrote:
Fri Mar 15, 2019 12:47 pm
Please confirm that you have a complete solution not just "sure it must be easy just add a checkbox" :)
JRD McLAREN
OK ..
but, I have not to much time for it at this time ...
I'll give you a feedback. ...
JRD McLAREN wrote:
Fri Mar 15, 2019 12:55 pm
Once you have time please suggest a complete solution which would work for all configurations
2 stroke and 4 stroke
well-defined shapes and composite shapes
JRD McLAREN
.. 2 stroke engine not require CAM sensor, they don't have CAM .. in most setups ....
(except Detroit Diesel for example .. )
..(and I'm not good programmer ... :( ) ..
JRD McLAREN
one POSITIVE UPDATE ...
IT RUN ... in SEQUENTIAL MODE ...
Trigger type - 60/2 VW
Operation mode - 4stroke without cam sensor
Use only rising edge - false
VVT mode - Second half
Thanks for all ... for advice..
..and sorry for my stupid questions ... :mrgreen:
We need a video and a picture of the board! :)
These are not stupid questions, we need to make this less confusing. Actually a very small change which would help a bit could be to rename
"4 stroke with cam sensor" into "4 stroke with well-know cam sensor position"
"4 stroke without cam sensor" into "4 stroke without cam sensor or with unclear can sensor position"
Does it makes sense? Can you propose a better wording?
JRD McLAREN
It will be OK ... (for me)
I have no idea, how is defined cam and crank in current rusefi source ...
..at this moment ...
and try to "fix" this one .. also ..
JRD McLAREN wrote:
Thu Mar 14, 2019 7:46 pm
I'm think, the right name for your trigger wheel templates are:
60/2 with Hall sensor (60/2)
60/2 with VR sensor (60/2 VW)
"STOP button" is great feature also ... .. as your Engine sniffer .. ;)
If you can see any other trigger wheel templates, try download this: https://imfsoft.com/files/master/software/FIRMWARE_FPGAV8_43_CPUV8_44.zip
Thanks ... for your time ..again ...
60/2 with Hall sensor (60/2) - is there such a thing in reality?
JRD McLAREN
this picture
https://rusefi.com/images/triggers/trigger_8.png
looks like standard BOSCH 60-2 wheel, read by HALL sensor ...
..it may be inverted, for some kind / type of HALL sensors ...
and this one
https://rusefi.com/images/triggers/trigger_20.png
looks like BOSCH 60-2 wheel, read and decoded by VR sensor + LM1815 or MAX9924 - 7
..as I wrote above ...
Appreciate your input, this is now part of https://github.com/rusefi/rusefi/issues/707
JRD McLAREN
russian wrote:
Fri Mar 15, 2019 5:36 pm
...some OPEL / Vauxhall car have HALL sensor on crank ...
...and some new VWAG have this combination ..
...and some users can have they own sensor and wheel combination ..
DSC_0385 (1024x576).jpg (341.93 KiB) Viewed 19914 times
How many narrow red logic output VR tooth are there and how many wide red logic output VR tooth? 57 narrow + one wide?
Obviously 58 narrow and zero wide in real life physical wheel and same 58 narrow and zero wide on Hall logic output signal I hope?
JRD McLAREN
Yes, you right ..
It is 57 narrow + 1 wide
In VR decoded logic is +1 wide tooth ...
Full scope of raw VR is on this picture https://rusefi.com/forum/download/file.php?id=4416
It is from my 60-2 trig. wheel .. on VR
JRD McLAREN
..we talking about this ..
Yes, the above issue is work in progress.
JRD McLAREN
4 Metal = real trigger wheel shape - green color
3 Hall = no Hall signal on the picture
2 VR = black "line" is the raw signal from VR sensor recorded on scope ..
Green one = is TTL signal coming out from MAX9926 (or any other vr controloer)
"zero crossing" are signal edges ...
(zero aka 0 have grey color)
Please join slack see https://rusefi.com/forum/viewtopic.php?f=13&t=1198 for details
ZHoob2004
Post by ZHoob2004 »
How many RPM is this being tested at? Could this be another case of the max8266 MAX9926 automatic gain issue?
JRD McLAREN
VR scope graph is recorded at "starter" .. 120-150 rpm aprox.
Could this be another case of the max8266 automatic gain issue?
what do you mean ..?? spikes ..?? or "different tooth readings" .. ??
Thank you! I will now edit history a bit to reduce confusion
ZHoob2004
Post by ZHoob2004 »
JRD McLAREN wrote:
Fri Mar 15, 2019 9:08 pm
Never mind, I did the math and I believe you would have to be turning at less than 12RPM for that feature to become a problem. More of an issue for extremely low tooth counts I guess.
MAX9926 has some watchdog at 80 or 85ms, this is becoming an issue during cranking if you have very few tooth on your trigger.
JRD McLAREN
..Oh ..
I know what Zhoob2004 mean with this context ...
If we have less than 12 tooth on trigger wheel, then HALL sensor is better to use ..
otherside..
If we have 58 and use HALL, then we can have problem on high rpm...
( "old hall" / type of sensors are slow )
