[rusEfi] 1991 Volvo 240 Racecar #49
Soldering skill: yes
Coding skill?: yes
Post by mck1117 » Sun Apr 14, 2019 2:56 am
This car is nearly the same as my 1993 Volvo 240's setup, but it's a different engine in a different car, so a new thread is in order!
The car is a 1991 Volvo 240 sedan, bought by myself and some friends to go budget racing. Since I'm in the Seattle area, we're planning to run with the Lucky Dog Racing League.
The engine is a Volvo b230 with around 2.25mm shaved off the head for 11.4:1 compression and a mild port, a gigantic camshaft, and long tube 4-2-1 headers.
The EFI setup is a Frankenso (for now), stock 60-2 crank trigger with VR sensor (on the flywheel), sequential fire injectors, 4 LS ignition coils currently running wasted spark, and a cj125 wideband controller.
Here's the car running (don't mind the vice grip battery cable):
Coding skill?: yes
Re: 1991 Volvo 240 Racecar #49
Post by AndreyB » Sun Apr 14, 2019 3:33 am
Soooooooo much free space in the engine bay!
Coding skill?: yes
Post by mck1117 » Sun Apr 14, 2019 4:06 am
Which is why my other 240 has a v8 in it :D
Coding skill?: yes
Post by mck1117 » Thu Aug 15, 2019 9:30 pm
I suppose I should provide an update on this car:
July 17 I took the car to a track day, running on Frankenso. Other than identifying a (now fixed) trigger performance bug, the ECU did fine. The car had some pretty serious windshield fogging problems since it was raining, but that wasn't rusEfi's fault.
Over the past few weeks I've switched the car over to run on microRusefi, and this car was the first started engine on the new microRusefi board!
