aux temp
atntpt
Soldering skill: yes
Coding skill?: yes
aux temp
Post by atntpt »
there is anyway i can display aux temp on tunerstudio?
Coding skill?: yes
Re: aux temp
Looks like this feature is not finished
	 * todo: finish implementation #332
	 * offset 2468
	ThermistorConf auxTempSensor1;
	 * offset 2500
	ThermistorConf auxTempSensor2;
atntpt
Coding skill?: yes
Re: aux temp
Post by atntpt »
Is it very dificult to do? It's only TS display part or is firmware related ? I guess it should be similar to iat and clt . Anyone willing to help ? I wanted to deploy a fan depending on oil temp
Coding skill?: yes
Re: aux temp
I might have implemented it or at least made progress.
You would need latest firmware. I am not ready to add a new dedicated gauge for aux temperature so new https://rusefi.com/s/debugmode = "Aux Temperature" added
aux1 is debugFloat1 and aux2 i debugFlost2, in Celsius
atntpt
Coding skill?: yes
Re: aux temp
Post by atntpt »
oh great tks! but it seems now with full pinout 1/2 and 2/2 that aux temp sensor input setting is missing
Coding skill?: yes
Re: aux temp
I do not think it was ever there. Anyway, you should see it in a different dialog
	dialog = otherSensorInputs,					"Other Sensor Inputs"
		field = "aux1 TempSensor ADC input",			auxTempSensor1_adcChannel
		field = "aux1 Bias Resistor Value",       		auxTempSensor1_bias_resistor
		field = "aux2 TempSensor ADC input",			auxTempSensor2_adcChannel
		field = "aux2 Bias Resistor Value",    	   		auxTempSensor2_bias_resistor
Just added to Full Pinout https://github.com/rusefi/rusefi/commit ... c01d229e07
