[rusEfi] Setup settings for Holden V8 #52
It's all about the code!
NickZ
Soldering skill: yes
Coding skill?: yes
Post by NickZ »
Hi
have a few questions regarding the setup for a Holden 304 V8 engine
I have a 36-1 tooth trigger wheel
8 LS1 coils in paired configuration so wasted spark
8 injectors paired wired like the firing order.
my firing order is
1-2-7-8-4-5-6-3
1. I can't find a firing order in the firmware (tunerstudio) that I can use.
2. I can't find away in the settings to select the 4 paired injectors to fire as pared like the wasted spark.
I am using my own custom board and have had it bench tested as a 4 cylinder and works great. I made one mistake and used PD14 as a coil out and have found it is default firmware fixed as a fatal error led, how can i change that easily. (im not really a coding person and could move the pin in the next revision of my board, but would like to test the current board on this engine).
NickZ
Coding skill?: yes
Post by NickZ »
Hi
my firing order is
1-2-7-8-4-5-6-3
Coding skill?: yes
Re: Setup settings for Holden V8
Welcome to the forum!
Just added your firing order into the firmware.
To move PD14 you would need to recompile firmware. If that's not trivial for you, I believe cutting a trace and hacking hardware with a jumper wire could be the best way forward :(
four pairs of injectors sounds like "batched injection mode" to me?
NickZ
Coding skill?: yes
Post by NickZ »
to get a understanding, my current ecu fires injection and coils in sequence, channel 1-2-3-4 and repeats in its batch paired injection, does this firmware fire channel numbers in firing order as selected ie: channel 1-2-7-8 my firing order 1-2-7-8-4-5-6-3.
Coding skill?: yes
Yes, firmware accounts for firing order while decided which cylinders are batches together in what sequence
you should see this in engine sniffer tab of rusEfi console
NickZ
Coding skill?: yes
Post by NickZ »
ok. i have had the engine start but only for a few seconds, using the engine sniffer i get coils and injectors with a good trigger pattern then injectors stop triggering but coils keep going, i can keep winding over the motor and coils keep triggering in the sniffer and the TDC line is at correct time.
i have a screenshot just catching the last injection pulse.
Screen Shot 2019-09-29 at 4.12.33 pm.png (662.83 KiB) Viewed 1018 times
NickZ
Coding skill?: yes
Post by NickZ »
After more testing anything over 500 RPM cuts the injectors and they wont come back until rest.
here is the current tune.
CurrentTune.msq
(135.77 KiB) Downloaded 36 times
Coding skill?: yes
Please post pictures or videos of your setup for our entertainment.
Please post a log file to help us help you. With your symptoms this sounds like engine works in cranking mode but does not run when it switches to running mode. MAP sensor not working/connected?
NickZ
Coding skill?: yes
Post by NickZ »
2019-09-29_15_55_01_978.msl
(554.48 KiB) Downloaded 108 times
Here is one log.
NickZ
Coding skill?: yes
Post by NickZ »
this are my Basic boards i have for Speeduino, i make a Arduino 2560 board to plug in, now im trying the same with RusEFI using the stm32f407, there is also a version of speeduino for STM32f407 but is not user friendly and i can't get it to compile at this stage.
I make a few other boards too that this plug in MCU will work on.
Coding skill?: yes
NickZ wrote:
Sun Sep 29, 2019 1:31 pm
did you mean stm32f407 both times?
"everythingfuelinjectOIn" is that a typo in domain name in PCB?!
NickZ
Coding skill?: yes
Post by NickZ »
yes and yes. i know. this board is just a prototype and the spelling mistake (well typo) will be fixed.
Coding skill?: yes
this is the root cause of your problem
Coding skill?: yes
And looks like this table has invalid default data, rusEfi bug https://github.com/rusefi/rusefi/issues/960
NickZ
Coding skill?: yes
Post by NickZ »
what should the values be? All zero's?
Coding skill?: yes
All '1'. But really just turn off "Use fixed baro corr from MAP" for now.
NickZ
Coding skill?: yes
Post by NickZ »
great. fix, now just have to tune it
thank you
Old Grey
Post by Old Grey »
I wish I had your enthusiasm, because this must be your 20th ECU.
NickZ
Coding skill?: yes
Post by NickZ »
this base is a production model ive been working on, With plugable brains is now universal.
Had the car running today. Runs awesome with this stm32f407 and RusEFI.
next is full sequential.
Coding skill?: yes
Re: Setup settings for Holden V8 #52
Congrats!
Hopefully this would eventually be the first rusEfi v8 which actually moved under rusEfi power - so far it looks like all v8 engines were only running while parked :(
ximite
Coding skill?: yes
Post by ximite »
Hi NickZ and Russian.
Im very excited with all.
I own a 97 Grand Cherokee 5.2 V8 (aka ZJ) running with a Protune 440 ECU.
But as I like to build my own toys, i´m planning to change to rusEFI asap.
I have 2 friends that own also ZJ. One of them are mechanic and other are car electrecist.
Can you share your project to give me a start point?
I also have some sw skills, and will try to migrate firmware to Platform IO that is very nice to handle with software.
Regards from Brazil.
NickZ
Coding skill?: yes
Post by NickZ »
My project started from another firmware ive been using on my own hardware but was limited to batch fire and wasted spark on a v8, Ive made a New MCU board to suit my current hardware to run rusefi so i can try sequential (even though i believe its not necessary to use sequential, but its the first question someone asks me) .
This first test was to see if the current engine configuration would run with rusefi and it does, so the setup is Paired injectors and batch fire LS1 coils, 36-1 trigger wheel on the crank pulley.
when i get the chance i'll rewire for sequential injection and coils.
ximite
Coding skill?: yes
Post by ximite »
Hi NickZ
Nice to hear you.
The setup that you talk about is the one i plan to do in my v8.
I will try your map and configuration and latter change to sequential injection with lost spark on 2 coil with 4 outs.
Thanks for share.
Regads from Brazil.
