[README] Lists of rusEfi cars
Locked
Soldering skill: yes
Coding skill?: yes
Coding skill?: yes
Re: Lists of rusEfi cars
Miatas
NA6
NB1 1.8 non-VVT
https://rusefi.com/forum/viewtopic.php?t=467 Frankenstein board, very early rusEfi vehicle
https://rusefi.com/forum/viewtopic.php?t=987 1999 green Miata with an ancient Flyin' Miata stage 2 turbo kit
https://rusefi.com/forum/viewtopic.php?t=1264 @NBytevenom 2000 turbo
https://rusefi.com/forum/viewtopic.php?t=1282 @RadMx5 - UK - Frankenso with Op-Amp Hall inputs, "inverted mode" in firmware - offset angle which is 359 - "changed crank pull-up resistor (R290) from 1k to 2.7k and now it revs higher"
https://rusefi.com/forum/viewtopic.php?t=1623 @scramblr
NB2 1.8 VVT
https://rusefi.com/forum/viewtopic.php?t=1095 official rusEfi "red" test mule - Frankenso with 5K cam/crank pull-ups
https://rusefi.com/forum/viewtopic.php?t=1536 France
Coding skill?: yes
v8
https://rusefi.com/forum/viewtopic.php?t=864 Dodge Ram - zero meters driven - just the first v8 to ever get running under rusEfi control
https://rusefi.com/forum/viewtopic.php?t=1626 Holden
v12
work in progress :)
Coding skill?: yes
Retired rusEfi test mules
https://rusefi.com/forum/viewtopic.php?t=375 - Ford Aspire first ever rusEfi vehicle - sold while moving from Chicago
https://rusefi.com/forum/viewtopic.php?t=621 - Accord - looks like I got scammed and it had blown HG from day one :(
https://rusefi.com/forum/viewtopic.php?t=696 Dodge Neon - first PID usage - first high-current high-side requirement - sold since mission was accomplished
https://rusefi.com/forum/viewtopic.php?f=3&t=1457 Saab - Ion sense research mule - body scraped, ECU still at the garage waiting to be used
Locked
