subaru ej20k
cyrille
subaru ej20k
Post by cyrille »
Hello,
I introduced myself some time ago, here https://rusefi.com/forum/viewtopic.php?f=2&t=1266&p=27065#.
I finally decided to try the adventure, I ordered a frankenso kit that I should soon receive.
This is my first project of this kind, I will disturb you many times, but I would like to run my engine with this ECU.
see you soon.
Re: subaru ej20k
Do you know your crank wheel pattern?
cyrille
Re: subaru ej20k
Post by cyrille »
yes !
6/7
Re: subaru ej20k
Sounds like https://rusefi.com/wiki/index.php?title=Manual:Software:Trigger#Subaru_7.2B6_tooth I am not sure if that's the one affected by rusEfi MAX9926 watchdog issue or not.
cyrille
Re: subaru ej20k
Post by cyrille »
it's the same :cry: :cry:
rusefi not work with it ?
Re: subaru ej20k
Current Frankenso schematics is problematic for some subaru trigger. Please search forum about max9926 watchdog issues.
cyrille
Re: subaru ej20k
Post by cyrille »
Re: subaru ej20k
That link shows everything working. It looks like he had no max9926 issues, maybe i am confusing with another trigger. Someone with better memory maybe will clarify?
Re: subaru ej20k
The default max9926 chip might be an issue. We might need to make some modifications to make it work. However that depends on the crank wheel. Some older Subaru crank wheels had gaps while cranking at around 300 RPM. I'll have to look I think we made an add-on VR MAX9926 which bypassed the watch dog issue. Either that or we found a purchasable option. However has not been done yet, so it would be some new ground. As well if your crank wheel is from a slightly newer Subaru, then this is not a concern. We really need to know what crank wheel you have. If your crank wheel does not work, then we may need to make a modification to make it work. The good news is that rusEFI will work, but it might be a bit more work to get it to that point. We really need to verify which crank wheel you have.
cyrille
Re: subaru ej20k
Post by cyrille »
my car is an impreza wrx v4 (gt turbo in france) am98 and the crank is normally of the 6/7 type.
thank you
cyrille
Re: subaru ej20k
Post by cyrille »
Hello,
I received the rusefi, I just have to assemble it.
I will keep you informed of the progress of the work. :D
Re: subaru ej20k
Post by Abricos »
cyrille
Re: subaru ej20k
Post by cyrille »
Hello,
yes I saw it
