work in progress MREAdapter55 PnP 55 pin ECU
A lot of older vehicles (thus cheaper) in Russia use same or similar 55 pin ECU connector.
Those vehicle range from 8 valve https://en.wikipedia.org/wiki/Lada_Riva grandchildren of https://en.wikipedia.org/wiki/Fiat_124 to https://en.wikipedia.org/wiki/GAZelle light commercial vehicles.
We are still trying to get developers and https://github.com/rusefi/rusefi/blob/master/misc/Strategy_2019.md still applies. I believe we need a cheap plug&play solution for this 4 cylinder 55 pin market. At this point 6 and 8 cylinders if those ever used this 55 pin connector are out of scope.
https://github.com/rusefi/hw_55_te
https://github.com/rusefi/hw_55_te/raw/master/microrusefi55adapter.pdf
Re: PnP 55 pin ECU
There are at least three vendors using same or similar 55 pin connector:
* Bosch seems to be the oldest offering.
* Yanvar/January
* Mikas
At least two modifications of the connector were used, maybe three.
Yanvar and Mikas seem to be using same or similar slim case where microRusEfi maaaaaaybe will fit but extremely tight fit. I have a Mikas in my collection, looks like they use https://www.te.com/usa-en/product-963063-1.html which is available new from US distributors at about $15. We have a board for this connector! https://rusefi.com/forum/viewtopic.php?f=4&t=616
0261206683 MIVI3T64 Bosch uses a longer version of the connector which is available from China. TE support does not recognize this part, maybe too old maybe not TE maybe custom Bosch edition. PCB footprint is a bit different, we would need to modify the breakout board.
0261206683 MIVI3S64 (S instead of T) uses metal connector housing?!
My next step would be to get 0261206683 MIVI3T64 in my hands looks like it's a simpler option to begin with.
Re: PnP 55 pin ECU
TBD
Re: PnP 55 pin ECU
tbd
Re: PnP 55 pin ECU
@andreika has reminded me that rusEfi firmware was already used with this Chinese connector! So we would not need to measure the footprint again :)
https://rusefi.com/forum/viewtopic.php?p=26893
Re: PnP 55 pin ECU
Simon has created first draft of the pinout compatibility chart. I did not realize that BMW M70 v12 and https://en.wikipedia.org/wiki/GAZ-3102 had this pinout in common?!
Simon@FutureProof
Slack: Orchardperformance
Re: PnP 55 pin ECU
Post by Simon@FutureProof »
Thanks Andrey.
I will try to take a look at the Vauxhall and Volvo stuff too, wondering how similar they are now.
Do we think that we can get away with just one of those plugs?
Do we think they may be compatible or interchange?
Re: PnP 55 pin ECU
OrchardPerformance wrote:
Tue Mar 03, 2020 10:17 am
Do we think that we can get away with just one of those plugs? Do we think they may be compatible or interchange?
First phase is to investigate how our long connector would would work with original motronic cases and if there are variations of that case.
Many Russian vehicles use that other case with another connector, the small case and small connector. This case could be challenging for us but ideally we need two two boards to lure people with a promise of having a board for their existing case.
Simon@FutureProof
Re: PnP 55 pin ECU
One thought, does it need to fit the existing case at all? Just has to fit in the same space.
I have a motronic connector out of the car at the moment. I will take a look how hard it is to replicate an end plate.
Re: PnP 55 pin ECU
Tue Mar 03, 2020 3:30 pm
The whole idea of rusEfi PnP is design, fabrication and eventual user cost reduction. Reusing OEM cost is simplifying our life tremendously, we should do our best to fit OEM cases in my opinion - it would pay of by fabrication simplicity.
Re: PnP 55 pin ECU
Dron has taken a VAZ Bosch apart and well... that's a bit surprising.
Dron_Gus
Github Username: dron0gus
Re: PnP 55 pin ECU
Post by Dron_Gus »
And pcb size...
andreika
Re: PnP 55 pin ECU
Post by andreika »
yanvar51_gerber.zip
Dron_Gus
Re: PnP 55 pin ECU
Post by Dron_Gus »
Январь-5.1.1 / Yanvar-5.1.1
Re: PnP 55 pin ECU
https://github.com/rusefi/hw_55_te/ is the repo for this ^^^ case.
Need to call Cricut tech support - on these chipboard prototypes my X precision is amazing my Y precision not so great :(
Re: PnP 55 pin ECU
reminds me of the internals of modern SSDs :D
they are somewhat similar -– tiny boards with huge connectors and oversized enclosures...
Re: PnP 55 pin ECU
Re: PnP 55 pin ECU
Is Gary on this thread? Would he see comments if I were to make some?
Re: PnP 55 pin ECU
kb1gtt wrote:
Tue Mar 10, 2020 9:10 pm
I would assume zero speeduino people on the rusEfi forum thread if you are referring to rusEfi forum thread.
No idea about facebook viode thread.
No idea about many things really.
Re: PnP 55 pin ECU
@Dron_Gus has pushed a draft of this open source board
Re: MREAdapter55 PnP 55 pin ECU
Cardboard test of cap array clearance holes was a success.
We have https://github.com/rusefi/hw_55_te release candidate but we do not have test mules lined up :( Not sure what's the plan for this board now.
1marvin
Post by 1marvin »
I would be interested in trying this on a turbo setup the only issue is it is an inline 6 m20b25 same connector
1marvin wrote:
Fri May 15, 2020 3:24 pm
if it looks the same it should be possible to make it work
please get yourself a microRusEFI this would motive us to finish this board and make it work for your 6 cylinder application.
