2014 toyota tundra ?....
Joey120373
Post by Joey120373 »
Has a 5.7l V8 DOHC with vvt,
I don’t know if I will tackle this project, as it’s about as complicated as it could get, 4 cams with vvt, Etb and electronic trans control.
Not sure that the current RUSefi Code can handle dual vvt,
And the trans control is another issue. But, if I were to try it, I think it would be in a piggy back configuration. Where I could take control of the injectors and coils, then maybe the ETB and vvt after that.
It’s my main transportation so I don’t want to break it.
Probably the best plan would be to build an interface board/harness to the stock ECU, that way I can intercept the signals I want to and leave the rest as is.
Any advice welcome!
Re: 2014 toyota tundra ?....
My dream BMW N73 DI is more complicated, this v8 is easy :P :oops: :roll:
But I would not be messing with my daily driver, that's me at least.
v8 is Proteus territory. If you would be willing to do the leg work I am happy to fill firmware gaps. TCU I cannot promise but dual or quad VVT should not be a problem by the time you have this engine wroom-wrooming.
TopDown
Post by TopDown »
Joey120373,
My question is: What are you looking to do with your Tundra with any RUSEFI system as the Toyota is apparently NOT yet broken? Are you looking to do something special like a turbo/super charger or...? Hmmm, this is your daily driver... Yeah, forget this unless you have another daily driver in mind... ;)
Audrey, yes, your V12 is much more complicated. My old V12 is also in the offing and will be on an upcoming project as well only I have to redo at least one (actually both) of the heads as they were prone to dropping valve seats...
TopDown wrote:
Wed Jun 10, 2020 9:17 pm
Joey120373,
Yeah. I cannot recommend doing this on an already fully functional (and unmodified) 2014 Tundra. Toyota knows what they're doing. Don't F with it!
