Hello all.
I've seen some of the PCB's for the 121 pin ECU connector used on many Audi / Skoda configurations.
https://rusefi.com/forum/viewtopic.php?f=4&t=208
I was wondering if anyone has created a similar PCB already for the 80 pin connector, used on a number ov VW / Skoda / Seat engines including the early 1.8T and also VR6 configurations. If so, would you be willing to share the gerber file (or similar?)
I would love to get some PCB's made for this connector if possible, as I am planning to utilise Rus EFI on a few of my builds.
Thanks
80 Pin ECU 8-1393476
- image.png (1.24 MiB) Viewed 10963 times
Re: 80 Pin ECU 8-1393476
I have these connectors for sale but did not yet find time to list on eBay.
Do not have gerbers or breakout boards yet https://github.com/rusefi/rusefi/issues/1676 created asking Jared for help one day, will poke him if he even has time available for this.
Thanks AndreyB. I've replied on the issue with the KiCad files for the board. Thanks for the support!AndreyB wrote: ↑Thu Aug 06, 2020 6:41 pmI have these connectors for sale but did not yet find time to list on eBay.
Thank you for the connector files those are now in the library https://github.com/rusefi/kicad-libraries/commit/f1647b3050e1f6f694699f220a56b2f94e728fcb
Any progress on the breakout board?
To update the thread, rusefillc has now added files for this connector, should anyone need it.
https://github.com/rusefi/rusefi/commit/9541f38546ee3b9c559bb814b53956fb9e966679
rev 0.1 is mostly a success!
We forgot small middle latch and it looks side latch/pins were flipped - looks like the x-distances between plastic parts are flipped.
- 80_0_1_issues.jpg (183.67 KiB) Viewed 10019 times
Available on eBay now https://www.ebay.com/itm/333770287887
Does anyone have this 8-1393476-0 header? I'm desperately looking for one. That part number is for my 05 lotus. The vw part number does not work as I have that header on my counter. I can make the keys work however the pins are to wide. They are in the correct position but to wide to work with my connector.
All I have is https://www.ebay.com/itm/VW-Audi-80pin-ECU-Connector-Volkswagen-Jetta-Golf-VR6-Turbo-VAG/333685575469
Looking for relevant wiring diagrams see https://rusefi.com/forum/viewtopic.php?f=4&t=2129
Random note: Lotus 2ZZ-GE 04-05 has something very much similar but not exactly the same: breakout seems to be interchangeable, but not the header.
The pin layout and the shell is the same and the lock mechanism seems to work, but the pins are too wide to fit into the Elise female terminals.
