Andreas_28023
Posts: 22 Joined: Sat Aug 24, 2019 1:54 pm
Post
by Andreas_28023 » Fri Oct 09, 2020 5:54 am
Hello
In which direction should I measure trigger angle offset, alpha or beta?
Kind regards
Andreas
Posts: 1501 Joined: Mon Jan 30, 2017 2:05 am
Post
by mck1117 » Fri Oct 09, 2020 5:56 am
Andreas_28023 wrote: ↑ Fri Oct 09, 2020 5:54 am
Hello
Kind regards
Andreas
Skickat från min SM-N960F via Tapatalk
In this case, I think you want to use negative alpha. My car has the missing tooth roughly 90 degrees BTDC #1, and I enter 86 to get the timing light to match up.
Yours looks like around -60 or so.
Posts: 14778 Joined: Wed Aug 28, 2013 1:28 am
Post
by AndreyB » Fri Oct 09, 2020 6:01 am
Should we change parameter label from "trigger angle offset" to "trigger angle advance"?
Post
by mck1117 » Fri Oct 09, 2020 6:01 am
AndreyB wrote: ↑ Fri Oct 09, 2020 6:01 am
it's probably at least worth explaining in a tooltip
Post
by AndreyB » Fri Oct 09, 2020 6:10 am
Andreas_28023
Post
by Andreas_28023 » Fri Oct 09, 2020 6:41 am
Thanks
//Andreas
