I am actually "working" on a lowcost ECU, it isn't waterproof, it doesn't offer E-throttle, it hasn't got a lot of protections, and it doesn't purpose a lot of inputs and outputs, but it is simple (and fat)
The connectors are Dsub, a DB37 + DB9, I already have some of them. But I like them, it is reliable and cheap.
The main goal is 6 cylinders, in europe we have a lot of enthusiasm for BMW engines, they are strong and cheap with good gearbox.
I often look at them, and if I have a good occasion I will be ready.
Actually I have an 1JZ with MRE, I love it but I have some trouble with 2 VR sensors, and I want full sequential.
I like the idea to design my PCB for my "trabant"
This ECU is a lowcost and fat copy of the MRE, without the TLE, it uses the same STM with the "same" pins. It normally allows the use of the same firmware, without even modifying the INI file.
It Offers :
- 11 LowSide outputs 1.4A (High impedance injectors only, and only one by wire)
- 6 Logic Level outputs (5V only)
- CLT and AIT inputs
- TPS, MAP, AFR analog inputs
- clutch input
- Canbus
Optional :
- VR Conditioner (room for external board. An homemade board with arming voltage by RPM is in developement)
- CR2032 battery and support (for real time clock)
- [https://www.ebay.com/itm/MicroSD-Breakout-Board-fur-SD-TF-Karte-fur-Arduino-3-3V-6Pin/272215736621]MicroSD board[/url]
- Knock module (maybe later, don't sure about it)
- SPI board or bluetooth dongle
Here is the price for 5 fully assembled boards : (without delivery, connectors, case and VR conditioner) The case is a common aluminium 41x147x100mm
It is approx 10$ on ebay or aliexpress I am waiting New Year in order to order 2 boards, maybe in case I forget something.
Sincerely,
