Getting the order Right
Krakert
Github Username: Krakert
Post by Krakert »
Hi everybody!
Me and my dad want to upgrade a Honda VFR750V from 1988 with some modern tech.
That's why we have chosen to go with a Micro RusEFI.
However, we don't want to wast too much money because we don't know if it will work out in the end.
So I wanted to order the PCB on JLC.
I cloned the repo hw_microRusEfi and used the files in, \gerbers\0.5.0
But when checking al the parts I got this:
And I'm not completely sure if this is all good. Especially with parts labelled R21..R81 and CN17..CN14.
Is there somebody that could help me out with getting this order right?
Thanks!
Stefan
Krakert
Post by Krakert »
Duplicated.. removed
Re: Getting the order Right
We've stopped selling MRE kits since supporting MRE kits was a drain of very limited community resources. I am puzzled by an attempt to order 0.5.0 instead of 0.5.3 with sturdier USB connector.
https://github.com/rusefi/rusefi/wiki/Hardware-microRusEFI-kit-instructions
I wonder if the part you are missing is "mircoRusEfi kit comes 75% assembled - while many components are already mounted, about two dozens still need to be added. This includes both easy to mount components like main connector and harder to solder TLE8888 100-pin chip. Some soldering hints and tricks are discussed here. If in doubt of your SMD skills please consider fully assembled version."
Krakert
Post by Krakert »
Sat Jan 02, 2021 6:15 pm
I had read that part, and I do have the equipment to solder the parts. But I was concerned about the components in the list.
Because of these 0R and 10nF parts.
Sat Jan 02, 2021 6:09 pm
So I should go with 0.5.3? I couldn't figure out what build was best.
Simon@FutureProof
Slack: Orchardperformance
Post by Simon@FutureProof »
0.5.3 is the latest well tested revision.
Gepro
Post by Gepro »
I believe that OR is Optional Resistor
SHOf429
Post by SHOf429 »
Gepro wrote:
Tue Jan 05, 2021 8:53 pm
0R would be a jumper. Zero ohm resistor
Josh
94 Ford Taurus SHO
Frankenso in progress
Gepro
Post by Gepro »
I don't know, the ignition outputs from TLE isn't use for now, so the 4 0R resistors mustn't be installed. (for now)
