Hi Guys
I am having problems trying to get a spark with my current setup ,my project has just been uploaded https://rusefi.com/online/view.php?msq=491,
The current setup is K24, setup to run ind coils in batch mode ,great crank trigger pattern in the log but no spark .
i have had it running on sequential ,with the Exhaust cam as the second input , not sure what is the problem apart from the voltage at the coil
pin 1 input is not hi enough so its puzzling, any help would be great
My Build ,2005 Honda s type K24A3 Accord Help needed
Jtech2020
- Github Username: jmg200
- Slack: James Gar***
Gepro
Re: My Build ,2005 Honda s type K24A3 Accord Help needed
Hello,
did you check the sparks with plugs outside the engine ? Are you sure about dwell ?
I don't know "ind coils". Is it smart coils ?
Did you ever resolve?
I am now working on a Honda K adapter for Honda K https://rusefi.com/forum/viewtopic.php?f=4&t=2132 and might use your help a bit
