http://rusefi.com/s/hellenNA6 has landed
Primary test mule https://rusefi.com/forum/viewtopic.php?t=1926
https://www.ebay.com/itm/234060110093
HellenNA6 is a Hellen for NA6 and NA8 with 64 pin connector
Re: HellenNA6 is a Hellen for NA6 and NA8 with 64 pin connector
https://github.com/rusefi/rusefi/wiki/Hardware/Hellen/hellen64_miataNA6_94-a-schematic.pdf is the schematic for the board we have
https://github.com/rusefi/rusefi/wiki/Hardware/Hellen/hellen64_miataNA6_94-b-schematic.pdf if a draft of next revision with schematics readability improvements
Jesse how did you get this drilling so straight and nice?
- h64a-case.jpg (480.07 KiB) Viewed 4599 times
- h64a.jpg (772.05 KiB) Viewed 4599 times
Unfortunately i cant measure worth a damn, so the holes are a bit off. Used a drill bit and then step drill.
We are ready to declare HellenNA6 rev A a good enough success. At least three boards are available for sale at https://www.ebay.com/itm/334017109387
Finally on eBay https://www.ebay.com/itm/234060110093
