Getting accel enrich to function
Boostonabudget
Slack: Callum Henn***
Post by Boostonabudget »
thought id make a new post specific to ae just to aid in keeping things organized. i was informed to ignore the tps/tps table for ae and use wall wetting ect in the accel enrich page, not sure if i'm missing a setting ect but cant get any extra fueling or make any difference to the car going super lean and trying to stall. here are the last 2 logs and tune that include some pedal movement without any change that I've noticed. let me know if I've missed something or changed the wrong setting :)
https://rusefi.com/online/view.php?msq=538
https://rusefi.com/online/view.php?log=245
https://rusefi.com/online/view.php?log=246
Simon@FutureProof
Slack: Orchardperformance
Re: Getting accel enrich to function
Post by Simon@FutureProof »
Dude, WTF?
Your requesting the ECU give 50ms extra fuel all over the place. It's no wonder the AFRs in your logs are totally haywire.
You have to find out what a setting does before changing them at random. There is a reason the TPS delta map is set the way it is as default.
Boostonabudget
Sorry it took so long for a response, I was taking a bit of a break due to frustration. The reason that tune said 50 everywhere is because it actually made 0 change in fueling. Didn't matter if I had the whole table at 0 or 100 it made no change to the afrs or how the car behaved. Its now at all 0 as well as wall wetting at 0 because I haven't been able to make either work.
