Hi, I hope this is not a problem, I work with RealDash developer and manage to have connection with RealDash app (only for android on 1.9.5-beta1, beta version is only available for android, once is full tested the app be available for ios and windows) https://play.google.com/store/apps/details?id=com.napko.RealDash
Now I have connection via bluetooth with my custom board (in Proteus firmware 2021_05_04) bench tested without real motor running (only rpm and throttle position). If someone wants to test with a real working engine, they will be grateful to know that everything works well.
Screen capture:
RealDash support
hugovw1976
- Github Username: hugovw1976
Re: RealDash support
Great news!!!
duhafnusa4
- Github Username: duhafnusa4
- Slack: Jimmy *un*el
This is awesome!
hugovw1976
Now is in the official app, no beta version. You can download for Windows, iOS, Android.
It looks like they do not parse .ini file? Did they take a random snapshot version of output region and any other version is not really compatible?hugovw1976 wrote: ↑Wed Sep 01, 2021 1:40 pmNow is in the official app, no beta version. You can download for Windows, iOS, Android.
Waiting for my http://www.realdash.net/forum/ account to get activated
hugovw1976
Check this post: http://www.realdash.net/forum/viewtopic.php?t=1281&sid=fda50c6f6e2a8a5dc52277657ae56605 You can check the way it's connected to rusefi, not by ini file (sorry it's the only way I can connect) but you can contact the realdash developer (he is very open for support) for a true support for rusefi, actually I have installed latest proteus f4 firmware and my ecu still connect to realdash (but I know it's not the best way)AndreyB wrote: ↑Wed May 25, 2022 12:10 amIt looks like they do not parse .ini file? Did they take a random snapshot version of output region and any other version is not really compatible?
Fresh version of RealDash works!
* tested realdash 2.2.5
* tested over-usb-cable
* manual-ini-selection
* feb-2023-rusEFI-release
hugovw1976
Tested today with lates firmware April 2023 release Day 408 (rusefi_bundle_proteus_f4), over USB work flawless but with bluetooth HC-06 connected to usart2 (PD5, PD6 pins) connection it's unstable and connect and reconnect constantly. Don't know if it's because HC-06 module or software. I try connect with tunner studio over bluetooth and have the same trouble.
I'd say someone with 2chan or 4chan - i.e. one of boards officially with BT - should try
See also https://forum.realdash.net/t/rusefi-ecu-support/975
