[help needed] Frankenso: does anyone have pictures for this board
- Github Username: kylan8129213
- Slack: huh
i got a 1994 miata a built this board how does it look
hey i’m kylan i got a 1994 NA 1.8L miata i’m not the best at soldering so it is not pretty but let me know if you think it will work or if there’s anything that I should change or if you think it will blow up when I plug it in.
- A8560468-53F3-4137-A405-6E9690824592.jpeg (2.65 MiB) Viewed 16456 times
- 9953247E-FFB7-4902-B313-242ECEFFD79B.jpeg (2.52 MiB) Viewed 16456 times
Re: i got a 1994 miata a built this board how does it look
Please stop posting new forum threads. I will merge this one into your other one tomorrow.
In case of new threads I would have to suspect your account.
- Slack: huh
it started smoking from D1
- image.jpg (2.78 MiB) Viewed 16453 times
- Slack: Orchardperformance
Re: Frankenso: does anyone have pictures for this board
Merged the three open topics into this one, please try to keep the discussion of this Frankenso to this topic.
With the way the soldering looks it absolutely is not ready to plug into any kind of power.
If you have powered it up already you may have ruined your board.
Have you been able to look at the frankenso build information I posted and the video to see the quality of soldering you need for your board to work correctly?
Im 100% not surprised it let smoke out. Did you fix any of the obvious shorts or misaligned components? These kits expect a certain level of assembly ability. Getting it Because you are broke is going to end up costing you more money. For $480, the hellen would have been a smart investment.
not starting from +12 could be known issue - see https://rusefi.com/forum/viewtopic.php?p=19748#p19748
- Slack: huh
not taking power from car
so when I plug in the ECU it does not light up or turn on at all when I turn on the ignition of the car it only turns on and lights up when I plug in USB power. tuner studio is also not talking to the car at all and none of the gauges are displaying but it says that it is connected
Re: not taking power from car
Why exactly do you ignore my answer at https://rusefi.com/forum/viewtopic.php?p=42747#p42747?
PS: considering the overall state of this project it could be more complicated. Please use digital multimeter and schematics to confirm that Frankenso makes 5v. I suggest checking for 5v on red Frankenso while green brain board is removed.
- Slack: huh
what do you mean +12 ? what’s that
- Slack: huh
This is what’s happening watch videos please.
- 65680942651__2547F2ED-C4EA-454B-AF2E-A15C7F7E5837.MOV
- (2.22 MiB) Downloaded 266 times
- 65680922737__C52AB5B7-B697-4C51-B1DE-5F58AF59702B.MOV
- (3.72 MiB) Downloaded 273 times
- 65680909366__4D602AFB-4756-4000-9A91-78B4C463E532.MOV
- (1.34 MiB) Downloaded 273 times
- Slack: huh
also doing this with battery
- 65680956032__B601038A-391B-422E-89BE-CCB38A97BCEA.MOV
- (1.98 MiB) Downloaded 275 times
- Slack: huh
also this
- 65680967007__F6274572-6A02-4539-9B06-D2D389E9484E.MOV
- (2.49 MiB) Downloaded 263 times
Wait you connected 12v to this and fitted it into a car?
Have you done anything to rectify the soldering issues?!
- Slack: huh
yes I fixed any soldering points that looked very bad and fixed the capacitor that was smoking
Also the voltage does not drop when I unplug the battery to the car
Something is really very badly wrong with your build as there is no way the voltage should be doing what you showing in the video.
I am sorry your kit may now be irrecoverable at this stage.
You may also have done permanent damage to you car by connecting it after we pointed out it is not ready.
- Slack: huh
so what should i do? is there any jumper wires that I have to run on the board or anything specific that I have to do to the board?
Please take this vehicle to a professional performance shop.
- Slack: huh
But what about the ECU the car works fine with the stock one
Please post high quality pics of the board as it is currently
- Slack: huh
what looks the most wrong and this and the main reason why it’s not talking to the car
- image.jpg (2.47 MiB) Viewed 16372 times
- image.jpg (2.35 MiB) Viewed 16372 times
- image.jpg (2.78 MiB) Viewed 16372 times
- image.jpg (2.7 MiB) Viewed 16372 times
- image.jpg (2.32 MiB) Viewed 16372 times
- image.jpg (2.63 MiB) Viewed 16372 times
- Slack: huh
both
- image.jpg (2.4 MiB) Viewed 16372 times
- image.jpg (2.96 MiB) Viewed 16372 times
- image.jpg (2.72 MiB) Viewed 16372 times
- image.jpg (2.19 MiB) Viewed 16372 times
- image.jpg (2.6 MiB) Viewed 16372 times
- image.jpg (2.15 MiB) Viewed 16372 times
- image.jpg (2.14 MiB) Viewed 16372 times
this looks most wrong
- Slack: huh
where?
this?
this?
- image.jpg (1.56 MiB) Viewed 16370 times
You still have soldering and misalignment issues. Plus +12 also.
- BDF2C0CC-D74E-4C82-B35C-8DF023610CD8.png (4.79 MiB) Viewed 16368 times
Have you soldered a 0R resistor in place of the Diode D1 on the green board?
- Slack: huh
yes and it has worked fine
is max9926 Super important for the EC you to talk to the car?
It is the incorrect component.
This may have caused even more damage.
- Slack: huh
+12 volts
