F103 Wideband Controller
- Dron_Gus
- Github Username: dron0gus
Re: F103 Wideband Controller
Finally arrived.
Some issue with fitment. Thanks to plastic enclosure you just need to push it harder. Acceptable result for development with no enclosure on hands.
- 20220517_104622.jpg (846.69 KiB) Viewed 14828 times
- 20220517_104518.jpg (1.14 MiB) Viewed 14828 times
- 20220517_104452.jpg (1002.93 KiB) Viewed 14828 times
- Dron_Gus
Some progress.
Next step is settings.
PS communication is over UART 115200. Next step is CAN.
TS now can read livedata from 1f_rev2 wideband.Next step is settings.
Fresh rev3 hardware
now targeting 26 pin small square case
now with some spare digital inputs
now using 64 pin F103
https://github.com/rusefi/rusefi-hardware/tree/main/wideband-F103
DAC output works! Next step to merge the DAC code into official repo and fix PCB dimentions.
It's getting really interesting. Unfortunately I have 5 boards to assembly with rev2. But you are already in rev3 .
I think I will wait until the things be more stable. Also the stm32 mcu seems be out of stock. On this board do you use a Chinese version?
stm32/gd32 questions is now clarified on https://github.com/rusefi/rusefi-hardware/blob/main/wideband-F103/readme.md my boards are a mix depending on what was available at time of order.
Also added a link to rev2 firmware binaries.
At the moment I am not sure if I will be ordering rev 4 on Tuesday or much later, overall this F103 is very much in the air.
I have bought today two gd32f103. I will assembly the rev0.2 to see if works properly. I have also with me two ch32f103 do you think that will be possible make this one works also?AndreyB wrote: ↑Sun Sep 04, 2022 3:00 pmstm32/gd32 questions is now clarified on https://github.com/rusefi/rusefi-hardware/blob/main/wideband-F103/readme.md my boards are a mix depending on what was available at time of order.
No plans for ch32f103 sorry, each extra chip is huge amount of effort.
It takes time https://github.com/mck1117/wideband/pull/164 15 days so far no feedback no merge
Nissan uses 4 wire "middle band" sensors, do these have anything in common with our WBO logic?
https://github.com/rusefi/wideband/issues/12
I got one to work here: https://rusefi.com/forum/viewtopic.php?p=43610#p43610
Nope, they're basically just "source voltage and measure current" type devices, no active control really needed.
@Dron_Gu: Which enclosure is this? It looks very nice
Thank you!
Thank you!
- Dron_Gus
But with slight modification (planned for V2) should also fit into https://aliexpress.ru/item/4000811747039.html
Stock ECU
hard wired to battery
quick engine restarts seem to have a problem:
on engine cranking controller seems to go into heating mode where it takes a while to re-heat what is supposed to be a hot sensor
- WhatsApp Image 2023-03-19 at 16.59.13.jpg (203.39 KiB) Viewed 11990 times
- stock_ecu_few_engine_restarts.zip
- (66.69 KiB) Downloaded 224 times
- Dron_Gus
Battery voltage drops down to 8.53V (actually seems even lower) during cranking. This cause controller to switch to SensorNoHeatSupply state and after battery voltage rises above 9.5 - start heating from the beginning.
https://github.com/dron0gus/wideband/blob/master/firmware/wideband_config.h#L55
Something like 2017-2019 Audi A4 Upstream Front Oxygen Lambda Sensor 8R0906262 8R0906262E would be the sensor
