[Success Story] W124 E320 Wagon M104 [Proteus]
duhafnusa4
Github Username: duhafnusa4
Slack: Jimmy *un*el
Post by duhafnusa4 »
Hi its me again. Doing more rusefi stuff on another W124. This time a wagon.
Its getting a 5 speed swap and with that the new flywheel is 60/2, so why not install a proteus and have a party?
Engine is staying stock for now, using oem sensors (ill add part #s later). But heres the specs:
1994 E320 Wagon
3.2 M104 (DOHC inline 6, VVT intake cam)
5 Speed Manual 717.412 with single mass flywheel
Proteus using stock wasted coils (has 3 piggies), injectors, iat, map, with AEM wideband
duhafnusa4
Slack: Jimmy *un*el
Re: W124 E320 Wagon M104 [Proteus]
Throttle body is going to be interesting. The cable goes to it, but if I researched correctly, it only triggers the PPS that is inside the throttle. The actual throttle movement is electrically controlled.
What a PITA.
duhafnusa4
Slack: Jimmy *un*el
MAP:
duhafnusa4
Slack: Jimmy *un*el
W124 Circuits.pdf
(399.49 KiB) Downloaded 416 times
duhafnusa4
Slack: Jimmy *un*el
duhafnusa4
Slack: Jimmy *un*el
duhafnusa4
Slack: Jimmy *un*el
augenblick
Post by augenblick »
How K R E A T I V do you want to get? Swapping your TB to a 96+ TB which is fully DBW would only require the TB swap and adding in the pedal position sensor from a W202 or W210.
duhafnusa4
Slack: Jimmy *un*el
augenblick wrote:
Mon May 09, 2022 6:32 pm
Im using a pedal position sensor from a W163 ML320. Its nice because it mounts in the engine bay and the stock throttle cable will connect to it (with a different end added). Minimal fabrication and no physical pedal change needed.
As far as throttle im looking at a 96+ like you states or a bosch motorsports one. Fun fact the GM v6 etb bolt pattern shares 2 bolt holes with the M104, 2 are misaligned. I could make an adapter...
augenblick
I'm seeing conflicting information about TB bore size, and I can't seem to find my micrometer, but hasty tape measuring showed a 01 M113 4.3 TB bore to be about the same size as a 94 E320, somewhere in the ballpark of 70-75 mm. You'd either need a spacer plate or some modding to get clearance, but other than that, it looks like it might fit.
duhafnusa4
Slack: Jimmy *un*el
augenblick wrote:
Wed May 11, 2022 4:55 pm
yeah i need to get one and check fitment. Otherwise Im going to buy a bosch motorsports 68mm.
duhafnusa4
Slack: Jimmy *un*el
ended up ordering the Bosch Motorsports 82mm throttle (0280.750.101)
Itll fit with a bit of love LOL.
Also found this nice bosch spec sheet.
bosch 82.png (43.81 KiB) Viewed 15142 times
duhafnusa4
Slack: Jimmy *un*el
IAT, CLT sensors working!
Intake manifold flap working!
Fuel injectors working!
Going coil on plug with Bremi 06E905115FKT6 (audi "R8" style)
duhafnusa4
Slack: Jimmy *un*el
duhafnusa4
Slack: Jimmy *un*el
Adapting the 82 mm bosch ETB (getting this cut out of alum, printed for fitment).
Intake manifold flapper for low/high speed torque and hp stuffs. Its just a pwm solenoid with a vacuum chamber.
Got rid of the dummy stock coils and went VAG coil on plug. Initial will be individually wired wasted, then sequential later.
duhafnusa4
Slack: Jimmy *un*el
found this for HFM mercedes! entire sensor values list! THIS IS GOLD
http://manual.startekinfo.com/manual/JSP/e2/1_1/m23.jsp#8.1
duhafnusa4
Slack: Jimmy *un*el
First Start attempt on the proteus worked! Still waiting on wideband controller, and probably has some vacuum leaks, but it runs and idles :D
Ill take a video once the wideband controller comes in and such. but good things! Tune and log are on REO
duhafnusa4
Slack: Jimmy *un*el
