m102 2.3 8v mercedes E190 PROTEUS
i just finished building rusefi proteus for my car just a question,proteus can support 12 volt logic level from hall sensor,my hall a=sensor denso hondamatic works with 12 volts and outpouts 12 volt square signal,is good to go or i will fry the ecu?
Re: m102 2.3 8v mercedes E190 PROTEUS
Yes proteus support +12 digital inputs
thank you andrey
placed 62 -2 triggerpulley and hall sensor
- efi.jpg (402.69 KiB) Viewed 11784 times
just a question rusefi dont have squirts per cycle?
on speeduino used 2 squirts ,on 4 squirts i have very rich idle
This sounds like 2 squirts per cycle = batch injection.
4 squirts per cycle = simultaneous injection
and 1 squirt per cycle would be sequential injection.
How are your injectors wired in?
