Hellen Ford Taurus SHO
This means Hellen
duhafnusa4
Github Username: duhafnusa4
Slack: Jimmy *un*el
Post by duhafnusa4 »
My secret projects. Maybe will work with Ford 5.0 hellen?
ECU pinout
Re: Hellen Ford Taurus SHO
Ford 60 pins is at step 5 out of 7 https://github.com/rusefi/rusefi/wiki/Plug-In-Board-Process https://github.com/rusefi/proteus-mustang5.0-60-pin
Ford 104 which seems to be more relevant here is at step 2.5 of 7, i.e. more or less nowhere.
duhafnusa4
Slack: Jimmy *un*el
makes sense. proteus with adatper might be better...
Simon@FutureProof
Slack: Orchardperformance
Post by Simon@FutureProof »
I just did a mustang cobra 4.6 engine on an MRE if the info is of use here.
One thing we may have to sort out is the EEC-V era cars seem to use a weird coms protocol for the rev counter and coolant temp.
J1850 was used from 1997 to 2004 according to Dave.
dbh97
Github Username: chuckwagoncomputing
Slack: dbh97
Post by dbh97 »
In my head, the way to do this is to make an ELM327 Hellen module, and let it do the heavy lifting. Interfacing with the ELM327's AT firmware should be easier than implementing n weird serial protocols.
Simon@FutureProof
Talking to Lloyds about a way to maybe hack the clocks, going to grab an old set of ford focus or similar eec-v clocks and see if we can directly drive it with a pwm carefully applied to the back of the clock PCB.
My thinking is that the clock probably has an interface IC and some kind of stepper drive IC I suspect we could PWM the stepper drive directly if we have a set of clocks to attack.
Will follow up with what I can find.
Drew is having sad experience with those 60 pin adapters at the moment. Stefan has some info.
