Anti-Lag
ELMEPRO
Anti-Lag
Post by ELMEPRO »
The Anti-Lag function is used with turbocharged engines to increase turbine speed when the throttle has been closed. This is typically of use during gear changes to prevent the turbo from stalling and needing to build pressure again after the throttle is re-opened.
The amount of pressure developed by the turbo is primarily controlled by the amount of additional air being provided. This additional air can be delivered via the throttle body. To provide additional air, the throttle stop is set so that the desired amount of additional air required is delivered and then the TPS (throttle position sensor) re-calibrated to be 0% at closed throttle. To keep the idle speed at a normal level the Rotational Idle function should then be Enabled and configured. DBW throttle application do not require Rotational Idle as the throttle can be controlled during anti-lag operation and does not require changes to the throttle stop.
anti lag options
Arming Engine Demand 0-100%
Activating Engine Demand 0-100%
Min RPM
Max antilag activation time
Max coolant temp
Min coolant temp
Function explanation
The amount of Engine Demand (TPS for Cable Throttles or APP for DBW Throttles) that must be exceeded to arm the Anti-Lag function. This is used to initially develop enough air flow to have an effect when the throttle is closed. (Default=50)
The amount of Engine Demand (TPS for Cable Throttles or APP for DBW Throttles) that must drop below to activate the Anti-Lag function. (Default=1.0)
Min RPM
The Anti-Lag function will disable below this amount of RPM. (Default=3000)
Max Time
The maximum amount of time that the Anti-Lag function will operate until conditions have all been again met. This is to prevent possible engine damage if an excessive amount of time is spent in anti-lag conditions. (Default=5.00)
We need two maps
Enrichment
Ignition Advance/Retard
Info from haltech
Do we have time to make it passible?
Im correctly installing ETB on engine!
Re: Anti-Lag
Re: Anti-Lag
@TBM has contributed some antilag code! Looks like at the moment it adjusts idle valve, timing and fuel. Also partial spark cut.
No ETB so far.
TBM
Github Username: TurboMarian
Slack: Marian
Re: Anti-Lag
Post by TBM »
ETB air adder for ALS is working now :D
Merry Christmas! 🎁🔔🎄
jasaircraft
Re: Anti-Lag
Post by jasaircraft »
Hello,
within the ALS window, there are 3 tables although its not specified what each one do, is there any info on this?
Also, for the older rally cars that dont have ETB, could rotational/roving idle be implemented?
I remember working on a m800 subaru with rot idle and it was possible to change the fuel cut sequence, really cool as you could choose which sounded better lol.
I have also seen MS3 implementation of this and there is a spark % cut table for antilag besides ign adjust and fuel adjust and also an injection cut table for rotational idle, that way you can have zero fuel cut after a certain tps/rpm in order to have a smooth transition to full cylinders.
jasaircraft
Re: Anti-Lag
Do we have a ALS state indicator in TS?
jasaircraft
Re: Anti-Lag
TBM wrote:
Mon Dec 26, 2022 11:44 pm
Hello, could we have a brief explanation of the variables and tables in the ALS window?
