I have a random Proteus 0.4 which no longer powers up by +12v, do we have any power supply troubleshooting/test points documentation?
Yesterday it has worked I've used it to test SD card logs.
Today blue LED blinks if I power via USB
First soldering issue I found: GND pin 19 at the PCB was not beeping to GND pin 20. Re-soldered pin 19, at least GND test pad beeps to input wire GND now.
What next?
proteus power supply troubleshooting
Re: proteus power supply troubleshooting [solved, cold solder joints]
Well, I've randomly resoldered pin 18 and now this unit is alive. So somehow two solder points have just failed at the connector
