Hello!
Need help adjusting throttle.
I did everything according to the instructions.
(video report)
after calibration the throttle does not work properly
https://youtube.com/shorts/pv_FYLBo93o?feature=share
____________________________________________________________________________
my throttle - https://aliexpress.ru/item/1005001316304007.html?spm=a2g2w.orderdetail.0.0.74b64aa6TjNWTV&sku_id=12000015672592996
my pedal - https://disk.yandex.ru/i/YynZiinwe0DY-g
Calibrate Electronic Throttle Body
Re: Calibrate Electronic Throttle Body
please upload your tune/calibrations https://github.com/rusefi/rusefi/wiki/HOWTO-upload-tune
please upload a log showing working TPS if you move throttle manually without power https://github.com/rusefi/rusefi/wiki/HOWTO-upload-log
anything ETB on bench first suspect is power supply which is unable to produce enough amperage, sometimes 5A is needed. please provide a photo of your power supply
please try setting PID randomly something like https://rusefi.com/online/view.php?msq=1383&dialog=etbDialog or https://rusefi.com/online/view.php?msq=1254&dialog=etbDialog or just try settings from different not default tunes
please use youtube since yandex disk error
power supply - https://youtube.com/shorts/moU0E062roE
all videos reupload on YouTube
Need calibration and logs at rusefi.online
I will double check if instructions cover bias curve validation. Please set p=i=d=0 and move pedal, some vaguely reasonable movements expected from etb
Rattles in place
I will attempt making a reference p=i=d=0 video on the weekend
SOS
Hello!
(when i manually unscrew the damper by 98% it start to react correctly.)
C'mon, red blinking indicator clearly tells you that your TPS calibration is incorrect. Until you get TPS calibration right you are not in the position to control it reliably.
Kind of our fault - we have a mechanism to stop ETB in case of sporadic error like yours but it might be broken
https://github.com/rusefi/rusefi/issues/5056
