2022 Canam
2022 Canam
Looking to set rusEFI on a 2022 Canam side-by-side vehicles.
WhatsApp Image 2023-11-15 at 19.23.07_d54be4fa.jpg (278.42 KiB) Viewed 19446 times
Re: 2022 Canam
I have the wiring diagram but I am failing to comprehend it :(
https://github.com/rusefi/rusefi_documentation/blob/master/OEM-Docs/CanAm/SSV%202022%20MAVERICK%20-%20Wiring%20Diagram.pdf (same file has two versions of the pinout just to make it more fun)
Seat belt switch how hard could that be right? With stock ECU Pin B OR/VI wire reads some sort of switched +12 volts. It goes to a JT (junction?) with VT/GY? Which goes where? Maybe same is mentioned as oxygen sensor heater+?
Re: 2022 Canam
Well there is also this legend saying that green color code is ground. So the +12v I am seeing is some pull-up. Weird.
Alex90
Re: 2022 Canam
Post by Alex90 »
Screenshot_20240114_112030_Adobe Acrobat.jpg (293.62 KiB) Viewed 16957 times
Hi dear, i' m Alessandor, i work on brp seadoo very similar to this, maybe somethink was wrong, i try to find new eletrical diagram but sure lambda heater going in this junction, see fuse name.
Have you develop more for this veicle? I need to build one ecu for this, new version, very similar to hellen 112 17 but different pinout
Re: 2022 Canam
Ha, the black one has fuel system issues but stock ECU deals with it! We have a chance to play with closed loop range settings
WhatsApp Image 2024-03-14 at 13.45.23_7eb0e610.jpg (327.86 KiB) Viewed 6756 times
