Here are some engine specifics:
Audi S6/S8 V10 engine
90 degree V angle
Split pin crankshaft configuration and results in a desired
ignition interval of 72°
Crank sensor is 60-2
Firing order - 1–6–5–10–2–7–3–8–4–9
Factory direct injection - I have converted this engine to run port fuel injection with 10 injectors.
Can someone help me with setting up some areas in tunerstudio?
Fuel setup - injection control
Ignition setup - base ignition settings
Ignition setup - advanced ignition options
Thank you!
