24-1 TRIGGER BUT NO MISSING TEETH
thefastelephant
Post by thefastelephant »
Hello,
Am attaching the trigger pattern and the flywheel of an already EFI model single cylinder motorcycle.
Will it work with the firmware/board as is or or need some changes to the flywheel trigger.
Total 24 teeth with 1 teeth being the wide teeth. When the wide teeth passes the VR Sensor, engine is 5 degrees after-TDC as per service manual.
Re: 24-1 TRIGGER BUT NO MISSING TEETH
Next step is checking how signal actually looks with oscilloscope or tunerstudio logs or logic analyzer
thefastelephant
Will try to post a photo or log. Its my first ever attempt with a Standalone.
