Honda b Series trigger problems
Koullisgg
Github Username: koullizGG
Post by Koullisgg »
Merry Christmas to everyone
I hope you’re all having a great holiday.
I’m looking for some help with a trigger issue on my uaEFI ECU.
Setup:
24 teeth connected on C16–C17
1 tooth on C18–C19
I don’t get any trigger errors, but I’m losing RPM — especially at low idle and above ~2,500 RPM when using the 12/24 trigger.
I also tried a custom setup with 24 teeth on the cam, but sometimes the engine starts with incorrect timing and I can’t figure out why.
Has anyone experienced something similar or found a solution?
Any help or ideas would be greatly appreciated. Thank you.
Re: Honda b Series trigger problems
Your trigger setup is wrong. Proper trigger setup is in the FAQ at https://wiki.rusefi.com/uaEFI-Honda-OBD1/
Koullisgg
Post by Koullisgg »
I have tried the recomended onece in the QA what exactly is wrong with mine ?
Koullisgg wrote:
Sat Dec 27, 2025 4:45 pm
i did not find any logs or tunes links in your question, without any data I have to rely on telepathy
telepathy has shown me https://rusefi.com/online/view.php?msq=1793 which uses wrong trigger setting
it's hard to help based on zero hard info
Koullisgg
Post by Koullisgg »
My apologys sir am kinda new to this and also its been some very busy days
https://rusefi.com/online/view.php?msq=1794
Here this is the map am using now the car works fine but i just ignore the 1 thooth after 750 rpm basicly i just use it to get the rigth timing phase and then i ignore it as it had sync problem
