Firmware developent status
It's all about the code!
Soldering skill: yes
Coding skill?: yes
russian wrote:
Sat Jun 01, 2019 8:33 pm
https://rusefi.com/build_server/ is back in business
Now it's really back in business using USB-TTL instead of ST native VCP.
Next step trying different USB controller
https://www.amazon.com/gp/product/B01G85LFEK
Coding skill?: yes
In order to be the best open source project in our field we have to rely on best infrastructure. While rusEfi is probably the only open source ECU with unit tests and continues integration testing already, we still can use more tools to be even better. If anyone is interested to help here are some of the boring tickets: https://github.com/rusefi/rusefi/labels/INFRASTRUCTURE
Coding skill?: yes
rusEfi bundle files on https://rusefi.com/build_server/ now have a bit nicer folder structure and a bit less files to reduce confusion. Also readme.html is now included! :)
Coding skill?: yes
Initial setup could be a bit easier for future users once we document how to use https://rusefi.com/build_server/st_files/silent_st_drivers.exe
More details on this at https://github.com/rusefi/rusefi/issues/845
Coding skill?: yes
I have added some Windows 10 into my life so https://github.com/rusefi/rusefi/issues/849 and https://github.com/rusefi/rusefi/issues/816 were resolved
Can use some help with https://github.com/rusefi/rusefi/issues/858 investigation
Coding skill?: yes
Usability improvement: rusEfi console now comes with ST drivers and a button to install those. https://github.com/rusefi/rusefi/issues/845
Coding skill?: yes
Minor usability improvement - if your cranking fuel is zero due to corrections, at least you get a warning code now.
https://github.com/rusefi/rusefi/commit/1fce0201a55c45f8333883cc95589c701d5723d5
Coding skill?: yes
@mck1117 has contributed TunerStudio tooth logger implementation - currently works only for single VR channel but that's a great step forward!
where do we read about it?
the window to the left - what is it?
what's needed to get into this tooth logger?
Coding skill?: yes
puff wrote:
Sun Jul 07, 2019 10:12 pm
There is a slack room for this feature https://rusefi.slack.com/messages/CL8EYJSUX/details/
Coding skill?: yes
Too much usability maybe? Not sure. rusEfi console now has an icon to launch Device Manager since that's how you know which COM port to select.
Coding skill?: yes
Build server now uses gcc 8.3 (8-2019-q3-update arm) - as of yesterday it was gcc 7 from 2017.
Coding skill?: yes
A stepping stone for better firmware upgrade experience is "software DFU switch", this now works at least on stm32f4 - see https://github.com/rusefi/rusefi/issues/809
Clive Two.Zero is the guy on ST community forums without whom I would not be able to implement this so quickly. I've just paypalled him some $$ and I would encourage everyone to consider the same. His PayPal, Venmo and Amazon Gift Cards info at https://community.st.com/s/profile/0050X000007vuogQAA
Coding skill?: yes
rusEfi console new usability feature: auto-detect serial port.
Coding skill?: yes
I put a lot of emphasis on infrastructure and testing automation. In my opinion it was important to get https://rusefi.com/docs/unit_tests_coverage/ and we now have it :)
Coding skill?: yes
https://github.com/rusefi/rusefi/issues/924 fixed & some CI coverage added. Thank you @Fantomiaso for error report!
Coding skill?: yes
Coding skill?: yes
ETB target is using integer values #945 fixed https://github.com/rusefi/rusefi/issues/945
While originally discovered in relation to ETB, same defect was probably affecting VVT target value and maybe some other table lookup.
Thank you @mck1117 for spotting the issue!
Coding skill?: yes
Another juicy defect - https://github.com/rusefi/rusefi/issues/948 - good old buffer overrun!
this time it's the other way around - I've discovered and @mck1117 fixed :)
Coding skill?: yes
Coding skill?: yes
Build server now uses brand new GCC 9 compiler https://github.com/rusefi/rusefi/issues/1001
Coding skill?: yes
https://github.com/rusefi/rusefi webpage now has a lovely icon for https://www.patreon.com/rusefi
Right now my firmware focus is on ETB safety and multi-channel VVT. Vacation is over, this Saturday I hope to land in a warm country without a beach so should have time to code peacefully :)
Coding skill?: yes
Mar, 02 2020 status:
* playing with some GDI software, but now waiting for repaired MC33816 to come from Seattle
* Matt and DronoGus are working on different parts of getting stepper control using two universal H-bridged, that would give us stepper idle control on microRusEfi.
* A _lot_ of hardware to play with - v12 on Manhattan, v12 on Proteus, setting up microRusEfi fabrication.
Coding skill?: yes
@mck1117 has contributed a bunch of great code recently!
We have CAN status broadcast - our own custom protocol since ODB-II or else does not do broadcast as far as we know.
And now we've just merged multi-spark!
Coding skill?: yes
A few usability improvements:
Human-readable critical errors (what used to be called 'fatal' is now renamed to 'critical') are now available in TunerStudio, in the "Base Engine" dialog for now.
Some settings are now marked 'requiresPowerCycle' in the project - we would need to mark few more with this attribute, but at least we have a sample now.
Coding skill?: yes
In light of my hardware issue with trigger and while I am waiting for a Rigol @andreika and I will look into the state of tooth logging in rusEfi
https://github.com/rusefi/rusefi/issues/1284
https://github.com/rusefi/rusefi/issues/1285
https://github.com/rusefi/rusefi/issues/1286
https://github.com/rusefi/rusefi/issues/140
Coding skill?: yes
FSIO usability progress - rusEfi console now has decode_rpn command. More at https://github.com/rusefi/rusefi/wiki/FSIO
Coding skill?: yes
Someone has asked about Renix 44-2-2 trigger support. Well, it's really easy to add triggers into rusEfi so we have it now :)
https://github.com/rusefi/rusefi/wiki/All_Supported_Triggers
Coding skill?: yes
We now use TunerStudio native mechanism for critical error messages and less critical messages are displayed on Base Engine dialog.
Coding skill?: yes
Apr, 20 2020 status:
* Nick and Chris are focusing on GDI progress
* Matt is focusing on ETB https://github.com/rusefi/rusefi/issues/1240 https://github.com/rusefi/rusefi/issues/1336
* x number of Andreys are focusing on data gathering usability https://github.com/rusefi/rusefi/issues/1337
