Firmware developent status
PS: this is related to Proteus 0.6 with specific F7 where we are still having issues with incremental firmware update
@andreika has implemented ISO 15765-2, or ISO-TP in both rusEFI firmware and rusEFI console. rusEFI console part uses ELM327.
I have a random ELM327 which uses https://github.com/rusefi/rusefi_external_utils/tree/master/ELM327 CH340T USB driver let me now try it :)
So far zero response from unreliable KKmoon ELM327 USB Auto Scanner
I have this kind of KKmoon ELM327 which is v1.5 probably not original ELM. Those require +12v to run according to @andreika got some response now need to fix some bugs in rusEFI code.
Another unreliable ELM327 comes in tomorrow
Lua can now read and write both CAN buses on _all_ designs with two CAN buses.
@dron_gus has added stm32f429-disco compilation target which would be first usage of external SDRAM by rusEFI. 8MB on this specific board, could go a bit higher if needed.
No specific plan to use that RAM as of today but very shiny and very cool.
Just bumped ChibiOS to version 20.3.4 / RT 6.1.4 for no good reason, just prefer to keep up with ChibiOS major releases.
Next frontier https://github.com/rusefi/rusefi/issues/3794 again no specific reason for priority.
tmbryhn
Post by tmbryhn »
Am I the only one that keep gettign these kind of errors every time I update firmware?
Problem:
Can't set "Number of lobes (lobes/cam)" to zero. This keeps the HPFP feature enabled, and I get the same error regardless of what I do to the table. Load an old .MSQ from a previous firmware version where "Number of lobes (lobes/cam)"=0 disables the HPFP and fixes the problem.
tmbryhn wrote:
Fri Jan 21, 2022 2:25 pm
That's a vague question. Are you getting same message always about HPFP? I doubt that.
Firmware update often comes with new mandatory settings.
tmbryhn
Post by tmbryhn »
"Problem:
Can't set "Number of lobes (lobes/cam)" to zero. This keeps the HPFP feature enabled, and I get the same error regardless of what I do to the table. Load an old .MSQ from a previous firmware version where "Number of lobes (lobes/cam)"=0 disables the HPFP and fixes the problem."
Iow; I'm unable to disable HPFP feature by setting "Number of lobes (lobes/cam)" to zero unless I load an old .MSQ for a previous firmware version that already had this variable set to zero.
Please post a link to your tune on https://rusefi.com/online
Why? what prevents you from setting number of lobes to zero? Please provide more details screen shots error messages etc.
tmbryhn
Post by tmbryhn »
Thank you! I've just pushed the change we shall have new snapshot in about 20 minutes
I think https://github.com/rusefi/rusefi/issues/3806 is a show stopper - anything after Jan 18ish might have performance degradation in it, technically that includes latest release.
Oh we should have implemented this usability change a while back. Well, progress!
Does not work for analog inputs but at least works for something :)
Matt has made https://github.com/rusefi/rusefi/issues/3912 console connectivity bugfix
Very upsetting to be wasting time on https://github.com/rusefi/rusefi/issues/3923 BS :( Ordered a new to me used laptop as replacement primary device :(
Mitsubishi update: two crank and one cam trigger wheels
_someone_ should check that I got the rotation direction right, also VVT wheel was a bit ball parked would need real vehicle validation.
https://github.com/rusefi/rusefi/wiki/All-Supported-Triggers#mitsubishi
Status update: I have no idea what to work on, too many random desires without any way to sort those by priority. So I keep playing with my test mules.
007adr
Post by 007adr »
There a few things that i think can add to the overall rusefi experience , the engine protection side of things that ties in with the sensors fuel and oil pressure and the launch control/ flat foot shifting, if you can grab it from the speeduino code it would make your product nearly complete
007adr wrote:
Wed Aug 03, 2022 2:09 am
rusEFI and speeduino are completely unrelated codebases so we cannot simply grab code. For new functionality to be added into rusEFI please articulate a feature request with much, much more detail.
007adr
Post by 007adr »
Sorry buddy, ill post it in the feature request section, or do i do it here sorry for the confusion
Problem or not with instant RPM?
https://rusefi.com/online/view.php?log=961
compare to https://rusefi.com/online/view.php?log=955
Do we see a bug? Do we see an opportunity for any engine metric? Do we see totally expected behaviour?
@mck1117 i believe that we are not in a good place with newparse. Two months ago we've made the first step towards using it for real https://github.com/rusefi/rusefi/pull/4219 but no progress since, the current unfinished status creates more harm than good in my opinion.
Please find either a way forward or backwards under https://github.com/rusefi/rusefi/issues/4441 - one way or another we have to end up with a consistent clear implementation of this layer, not a combo of sad legacy and unfinished fancy.
Console usability progress https://github.com/rusefi/rusefi/issues/4625 hopefully works on all relevant version of Windows.
With the wmic win32_pnpentity magic I've discovered above startup frame can now be a bit smarter about firmware update.
https://github.com/rusefi/rusefi/issues/3985 progress - SD card has way more data points now, and I am not done yet!
They have gcc12-beta so we've at least migrated from gcc9 to gcc10.
Wed Oct 19, 2022 1:16 pm
@nmschulte has just upgraded us to gcc 11.3 which is current release!
Sad story: rusEFI did not compile with 11.2
Once in a while we randomly get "Error: RDP level is set to 1, try using Read UnProtect (-rdu) command in order to remove the Read Out Protection."
Root cause unknown :(
Work-around:
in console\STM32_Programmer_CLI\bin folder of your bundle you have stm32-remove-read-out-protection.bat action to address that
Now failing to read a byte from k-line :( k-line is supposed to be just a case of uart but something is not going well.
https://github.com/rusefi/rusefi/blob/master/firmware/hw_layer/kline.cpp
