KB1GTT's design practices
I figured I'd share some of the constraints of my design practices, as it seems that on occasion it's not clear to other folks.
I always engineer to work under what ever conditions I can think of as important. This may or many not follow code and compliance regulatory standards. I'm a big fan of regulatory standards like medical standard EN60601, as it specifies the hazards that have to be protected, then it's up to the design to ensure it's protected. While other standards like NFPA70 and UL establish a set of rules an claim that if you stay in those bounds you'll be safe. I know several engineering failure that have resulted in significant loss of life that followed the code, but were not safe. So as a design spec, I put compliance and regulatory constraints at the bottom of the barrel. They are typically in the barrel, but are generally only used to work as a minimal guide of safety specs. If I have a commercial product that has some kind of potential for inspection or a customer demand, then I'll follow regulator constraints more stringently.
As an example, when it comes to wire selection, I generally don't select based on NFPA70's recommendation for branch circuit wiring, as I'm generally not designing a buildings electrical distribution. I generally design machines. I some times use NFPA70 as a generic guide but that's all. I've read several of the standards they use to establish when a wire is safe vs. unsafe and I understand that those standards don't always apply to every machine out there. Take an EKG for example, where the bare metal is pressed against a human, and the human is electrified. There are places for these standards and places where they don't apply. Or take the example of coil wire, by NFPA70 you can't use a traditional coil wire, it's voltage and current rating are not appropriate per NFPA70. So I try to design to the physical worlds needs, not to a spec. I'll use the wiring standards established by NFPA70 as a guide, but that's about all. I've actually used safely 30A on a 18awg wire in a heating platform design. This is really off base with NFPA70, but was OK with UL.
So for automotive environments and DIY projects what does this mean. For something that's going to be build by a DIY'er, it means the IO should be really rugged as to prevent common mistakes in wiring from causing damage, as the damage can be costly. It means that ESD controls are minimal, so it should be well protected against ESD as that's often not understood by many mechanics. It also means that brain farts happen, and people flip the + rail with the - rail when making a split second decision. To me those are very clear probably situations, and we can protect against them. As well it's easy enough to verify that it's designed against such issues. So those should be design considerations. When it comes to temperature, that's a bit more wishy washy. There aren't any regulator laws that I know of, so it's a design practice that's base on reputation more than anything else. The environment that these will be operated is unknown by the designer. Are these going to be north of the arctic circle, or in the middle of a desert. We don't know. So we should try to keep a wide temperature range, and publish it what ever it is. However we really have to rely on installer and user to ensure it's used in an appropriate environment. I see 130F as 55C, so an ambient spec of 85C seems fine to me. This often means a device will need to be rated for 125C as it will likely make heat and there will be a temperature rise before it can dump the heat to the heat sink at 85C. However where I live I rarely see temperatures above 100F (40C) so I could suffice with a much lower ambient temperature. As well with automotive stuff, you generally have lots of air flow, however with industrial devices they are often in a box which can have an increased ambient temperature, relative to the environmental ambient. So in my take a device that's rated for 85C is good enough, but we really need to measure what it can handle for the max environmental ambient. Then we should publish that spec and let the install / user decide if it's OK for their needs.
Any how, those are just some misc notes about my general design practices.
abecedarian
Re: KB1GTT's design practices
Post by abecedarian »
Thanks for the clarifications. I agree for the most part.
RE wiring: I'm going to stick with my suggestions to be over-cautious and inspectors will never gaffe you for using the next size larger wire.
Also, all wire should be stranded and MTW/TEW for oil exposure resistance or alternatively SOOW (rated 600V) or SJOOW (rated 300V) cable if flexibility (i.e. subject to substantial motion or vibration) is a necessity.
However where I live I rarely see temperatures above 100F (40C) so I could suffice with a much lower ambient temperature. As well with automotive stuff, you generally have lots of air flow...
Where I live I often see temperatures near 110F, occasionally 120F.
There is little air flow around the ECU in my Toyota truck and similar conditions for the ECU in my motorcycle.
The former is mounted behind the left side front kick panel, which is also in the discharge path from the lower heater vents.
The latter is mounted to plastic body parts, under the rear cowling, behind the seat, and significantly protected from water ingress (even has a gasket around the harness where it enters the tail).
See the dilemmas?
Beware MTW/TEW/THHN low temperature ratings. They often loose the flexibility when the insulation gets brittle. SO SOO and such are far better about the low temperature flexibility. Where I work we switched to Oflex cabling to take it one step farther. In a car I don't expect much abrasion so you can use a much thinner insulation than SO or SOO, like PVC, or my preferred, silicon. The silicon jackets require an installer with some skill, as pulling it across a metal edge can damage it. However it's very flexible even at low temperatures, it has very good insulation properties, and very good temperature properties. However it's also expensive as all getup. I understand most OEM's use PVC wires, it's a good balance between cost and required features.
Temperature ratings are a hard one to really deal with. You really don't know what's going to happen until you build it, toss it in an oven and measure what happens. Also any were on a bike or car has far more air flow than when inside a sealed enclosure. Picture tossing the components in your bread box, then heating that up to the high environment temperature. You have nearly no air flow around the box, and certainly no flow inside the box. At least with a car or bike you get some air flow around the outside of the box. Ultimately I simply aim for cost effective high-ish temperature range devices. Then after that see what environment it can handle, then see if that environment meets the application. If not, re-spin or change the plan. I've seen ECU's bolted fuel rails, or the radiator to keep a controlled temperature.
abecedarian
MTW/TEW should handle 'most' use cases, even freezing weather. There may be motion, or vibrations, along the wire but the lengths are usually enough to allow that to spread over a larger area as opposed to a tight bend somewhere. SOOW or similar should handle most other situations and silicone jacket is expensive. And maybe worth noting that any cable can have its insulation damaged by improper installation procedures. Use pull bushings and appropriate grommets if necessary.
I separate THHN from MTW/TEW because they do have some differences in ratings and usage recommendations.
Besides that, my Toyota truck, in summer time, can exceed 130F interior temps and like I mentioned the ECU is mounted behind a panel and is subject to very little airflow, even with the windows down. And, I don't have air conditioning. :(
The bike's rear cowl, under which my ECU is mounted in a box within a box, can get too hot to tolerate more than a few seconds contact with a bare hand, in summer. In winter, not so much a big deal since it's often too cold to ride.
Not trying to argue but rather explain potential use-cases where temperatures can get towards the extremes.
