This board is an older brother of 6 channel injector module
I measured that 35uH injector from a reasonably small injector. Other injectors may have more uH which would cause more energy dissipated in the OVP diode. The datasheet for the P6KE30A notes a min of 20C/W from junction to leads. I don't know the resistance from the leads to ambient. I'd guess 50C/W to 100C/W is in the ball park. I'll assume 50C/W. Which means the 3W's dissipated will raise the temperature by 150C. This can be a problem for the ambient temperature as the diode junction needs to stay under 150C. I think the diode needs to have a better thermal path to the heat sink. Either that or less energy to be absorbed.Lets look at this another way to double check that the decay seems about right. From here http://en.wikipedia.org/wiki/Inductor#Stored_energy we get .5(.035H)(1A^2)= .0175j. Then from here http://en.wikipedia.org/wiki/Watt#Definition and assuming we dissipate at a constant 20 watts, the decay time would be .0175j / 20W = .0008S. Which is about what I expected and see in the simulation.
At 9kRPM that would mean if the injectors are injecting on a per rev basis, it would rotate/pulse 150 times in 1 second. So it would be in OVP decay for 150cycle/second x .001seconds/cycle=.15 seconds per one second of rotation. So 15% of the OVP heat is dissipated on average. 15% of 20W is about 3 watts total heat caused by the OVP MOSFET decay per injector channel.
Would IRF7413Z require a diode for injector control?kb1gtt wrote:I like the IRF7413Z, it's a 30V OVP MOSFET, with good switching times and it has the same pin out as the chips we have been using. This chip claims it can handle 32mJ, and as noted above and in my analysis some time ago, the injector I measured was 17.5mJ. I wonder why they don't advertise it as automotive. Perhaps they simply didn't follow some automotive standard. I know many automotive grade parts have testing that ensures a 0% failure rate. As far as I can tell from the datasheet, it holds all the critical physical specs required. All that for $0.44 in qty 1, how can you beat it?
Wow blast from the past! Glad to see you found my photos from that other forumrussian wrote: ↑Tue Aug 26, 2014 12:41 amFrom http://open5xxxecu.org/viewtopic.php?f=44&t=72&p=892#p892
