[info] 64 pin 176122 ECU connector board
Soldering skill: yes
Coding skill?: yes
I've realized that we do not have a thread for the 176122-6 connector board - this board was finished before the forum was created.
SVN repository
176122-6-connector.zip
Also available at our store
See also https://rusefi.com/wiki/index.php?title=Hardware:OEM_connectors#64_pin
sturovo
donator
donator
Re: 176122-6 ECU connector board
Post by sturovo »
Just to confirm that this board fits well with my 1999 MX5 ecu plug type.
For the 12v power pin (on my car ecu pin 1B) it would have been nice that there were more than 2 connection points on the connector board.
In my case I will need several power wires using the 12v connection including the 12 to 5v power supply, high side ignition driver feed, vbatt , alternator control, map sensor etc. It is unlikely that the ecu power pin will be the same on all applications so it probably not possible to have a universal solution. What could work is a separate break out area on the connector with say 5 connection points in a row that can be connected to where ever the power pin is via a wire jumper. A similar ground strip break would also be nice.
looks very neat!
this connector was natively used in this case? or it was just a lucky strike?
Coding skill?: yes
I've learned yesterday that 1994 Toyota Camry 4 cyl uses this same connector.
Coding skill?: yes
Applicable to same vehicles as AEM 30-2983C - see the list on Amazon
Honda 4 cyl 1990-1995
Mazda Miata 1990-2000
Coding skill?: yes
Re: 64 pin 176122-6 ECU connector board
Coding skill?: yes
can we please add the silkscreen to match the mazda ECU pinout? We can make the board up to 50mm tall so that we can use the extra space for the text
Coding skill?: yes
A more important suggestion would be to make the holes for the wires larger, the size we are using on all newer boards.
Coding skill?: yes
NBytevenom
64 Pin Denso connector solder points
Post by NBytevenom »
I ran into a bit of an issue when building a harness for an NB1 recently. I was using DIYAutotune's harness wiring and a Rusefi 64 pin breakout board. To get the stripped wires into the holes on the board, I'd have to remove strands. When I used an NB2 breakout board, the holes were plenty large for the wiring. Is there any way the next production of NA6/NA8/NB1 breakout boards can have larger holes?
Coding skill?: yes
Re: 64 Pin Denso connector solder points
I know what you are talking about exactly. Yes, current published getbers have larger holes and I've placed an order for a batch couple of weeks ago, you reminded me to go check when would I got those.
Coding skill?: yes
New version of the board has arrived - better silkscreen and larger wire holes. https://www.tindie.com/products/russian/ecu-64p-connector-bare-pcb-honda-miata-nanb1/
Old version on top, new version on the bottom.
Coding skill?: yes
If we decide to make our harness 175061-1 would be the smaller terminal (starts at 0.05$ in US) and larger one is 173631 (starts at 0.02$ in China or $0.20 in US)
Has anyone crimped these? Does it require a $200 tool?
Post by stefanst »
I've used needle-nose pliers. Not pretty, but: so far, so good.
Poor crimps have a wide array of problems, which can range from electrical fires, to high voltages which damage chips, to simply getting a wrong signal. I suggest following the MFG's crimping suggestions. At work I've seen what happens when you do not use the proper crimp tools. See page 3 of the below PDF from TE.
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Specification+Or+Standard%7F114-8005%7FB%7Fpdf%7FEnglish%7FENG_SS_114-8005_B.pdf%7F176122-6
Also on that PDF, from page 15 to half of page 18, there are several crimp tools noted. AKA they have like 100 different options, and getting the proper pin for the proper application is as important as doing a proper crimp. If you are considering making harnesses, I would suggest picking a gold plated pin which can handle at least an 18 awg wire from those potential reciprocals. Then get the official crimp tool for that pins. Notice they list the crimp tools for each of those pins, and there are like 20 different crimp tools. The below looks like a receptacle crimp tool which covers a wide range of crimp devices. It's about $400, others were more expensive, some wore $1k+
https://octopart.com/58521-1-te+connectivity-40281022?r=sp&s=wjpEYjG8RW62c8NDVwP77A
Hmmm, how to find the receptacles. that seems to be the key problem with this connector.
Coding skill?: yes
kb1gtt wrote:
Tue Jan 29, 2019 10:33 am
$50 is the threshold. https://www.amazon.com//dp/B078WPT5M1 has positive reviews.
Coding skill?: yes
Damn https://www.amazon.com/dp/B019ARWWFY has three versions how do we pick which one is most relevant for us? :(
Do you know which socket you are trying to crimp yet?
You will more likely get a better crimp if you try ordinary pliers like previously mentioned. These are simply limiting your abilities to make a crimp.
Coding skill?: yes
kb1gtt wrote:
Wed Jan 30, 2019 1:40 am
TE 175061 and 173631 as mentioned before.
I missed that in the prior post.
I see several options found here, for the 1mm wide tab receptacle with different AWG or MM^2 sizes.
https://www.te.com/usa-en/product-CAT-M9194-T273.html?q=&d=557498%20103199&type=products&samples=N&instock
Specifically your mentioned one is here
https://www.te.com/usa-en/product-175061-1.html
The wider 1.8mm has many options found here.
https://www.te.com/usa-en/product-CAT-M9194-T273.html?q=&d=557498%20103204&type=products&samples=N&instock=N
https://www.te.com/usa-en/product-173631-1.html
Maybe used 90302-1
https://www.ebay.com/itm/AMP-Crimper-tool-90302-1/163007277291?epid=1601427728&hash=item25f3fda8eb:g:du0AAOSw-Y9a2LPb
ENG_SS_408-7634_O.pdf
(179.2 KiB) Downloaded 179 times
s-l400 (1).jpg (15.65 KiB) Viewed 8181 times
Coding skill?: yes
Wow these 90302-1 are $800 new and you can find (old ones?) used for under $50.
Neobob22
Coding skill?: yes
Post by Neobob22 »
hello and first, congrats for the job !!
you'll know that Miata use 2, 3 or even 4 connector like that :
finally, i'll just need the 64 pins you done to connect my standalone ECU to the 96 harness of my Miata, but as I want to also add sequential spark and other sensor/switches in an out, AND it would be a benefit for your product to adapt to most of miatas, is that possible to make the same board for 76 pins in 2 rows like the TE 174915 here below ?
thanks ;)
Coding skill?: yes
Neobob22 wrote:
Mon May 06, 2019 9:00 am
which Miata uses 76 pin / 4 plug connector?
Dron_Gus
donator
donator
Post by Dron_Gus »
Subaru were using this kind of connectors up to 1996. Including 76 pin.
Neobob22
Coding skill?: yes
Post by Neobob22 »
MR2 turbo also and other toyota, sub, ford etc
russian wrote:
Mon May 06, 2019 1:12 pm
you're right, NA use 2 or 3 plugs depending on year, then NB1 3 plugs and finallyNB2 use 76pin but its a different shape like you have already done, in 3 rows !
i've been mistaken by https://www.diyautotune.com/product/diybob-breakout-adapter-nippondenso-76-pin/
with that in line, would you consider to make the breakout board for denso 76 pins 4 plugs connector in 2 rows like that or no interest ?
thanks !
Neobob22
Coding skill?: yes
Post by Neobob22 »
i imagine it's a no :geek: :mrgreen:
Coding skill?: yes
russian wrote:
Sat Apr 14, 2018 1:24 pm
 1) RESOLVED IN R0.2  Silk screen was made better.
 2)                   Add same silkscreen to back side.
