Forum slowness & everything else forum status
Re: Forum slowness & everything else forum status
I'm disappointed that this upgrade didn't include the shark with a laser on it's head.
So far so good for me. I have not had to re-login for several days. Yipee! it's getting better.
Added a couple of new bragging user profile fields - existing users, feel free to set on your profile
We seem to be affected by https://www.phpbb.com/community/viewtopic.php?f=556&t=2433446&p=14924966#p14924966
"The problem in 3.2.1 is caused by an update of the used vendor library fast-image-size.
This library has changed the behaviour for JPEG. They force to use the EXIF header for determine the image size, if available.
https://github.com/marc1706/fast-image-size/issues/34
This causes, that images which have an EXIF entry of size 2800px and a physical size of 1024px are declined, because the EXIF size is used as master information.
Workaround is to strip the EXIF from the image before upload or rolling back the fast-image-size lib. I did a rollback of the lib and everything works fine with 3.2.1 for me."
I'm receiving email notifications of some updates in my thread, although I don't see any actual updates there. Two or three notifications, once per day.
I have big lags
I have Android phone HTC one before like 3 days before I don't have any problems it's star today
Some potentially dead links on wiki
http://www.rusefi.com/wiki
100% scanned - 2000/2000 URLs checked, 1929 OK, 71 failed
This free service checks the first 2000 links on any website. For larger websites please subscribe to our Auto-check service - options.
Scan completed with 71 errors. Full report Retry dead links
Check multiple sites at the same time - free - login or sign up for a free account.
Check sites automatically on a regular basis with the Auto-Checker - see options.
Status URL Source link text
404 Not Found https://meta.wikimedia.org/geoiplookup script/src
404 Not Found http://www.te.com/documentation/whitepapers/pdf/sncomrep.pdf here
403 Forbidden https://octopart.com/176122-6-te+connectivity+%2F+amp-40532660 Octopart [301 from http://octopart.com/176122-6-te+connectivity+%2F+amp-40532660]
404 Not Found https://www.eficonnection.com/eficonnection/wire.aspx http://www.eficonnection.com/eficonnection/wire.aspx [301 from http://www.eficonnection.com/eficonnection/wire.aspx]
403 Forbidden http://forum.pgmfi.org/download/file.php?id=6969&mode=view http://forum.pgmfi.org/download/file.php?id=6969&mode=view
found by https://www.deadlinkchecker.com/
testing primenotify
https://www.phpbb.com/customise/db/extension/topicpreview/ installed just for fun
Just bumped forum software version. There was a small issue but things should be fine now, let me know if you see any weirdness.
I am receiving very few forum notification emails today Has anyone noticed the same since Sunday morning?
Weird, looks like I've lost the checkbox to get email notifications about subscribed posts? Just put it back and email are coming again.
- board_preferences_edit_notification_options.png (32.66 KiB) Viewed 26545 times
Just bumped wiki and php versions, let me know if you see any issues.
Whole site was down today this was an https://www.ionos-status.com/ outage.
It was scary at some point but looks like forum was successfully upgraded.
Also I've learned how to change post date/time using a plugin meaning I can now insert posts on top of threads if needed
Recent forum upgrade could have messed up video embedding, looking into this now
For example
For example
video embedding was somewhat awkward - i couldn't watch then on the forum using android devices.
media embedding seems to be fixed now?
Re: Crimp notes & splice connection
it seems it's not the first time I see such stuff :
was it videos?- AndreyB
That's phpbb-mediaembed plugin trying to display amazon product links nicer. I have mixed feelings about these huge vertical images so these are disabled now.
Let's welcome the new look of https://rusefi.com/!
The html is available at https://github.com/rusefi/rusefi/tree/master/misc/www for anyone to offer CSS improvements or maybe mouse over color change or maybe some icons etc.
When uploading csv files (4.8MB) using my Safari I get HTTP error in the end of it, and the file is not uploaded.
would zipping be a suitable workaround?
it's somewhat intermittent. Two days ago it worked from the second attempt, today for some files i had to try multiple times, for others it just worked fine, so not sure if zipping would work, but i'll try the next tine i get an error.
Forum software was just updated a bit & settings now allow search for very popular terms like "miata" or "power supply"
Chart of forum posts per day, no idea what this chart means.
Row data attached, this was prepared using
SELECT date(FROM_UNIXTIME(post_time)), count(*) as count
FROM `phpbb_posts`
group by date(FROM_UNIXTIME(post_time))
order by date(FROM_UNIXTIME(post_time))
- chart.png (43.16 KiB) Viewed 24857 times
- rusefi forum posts per day - phpbb_posts.csv
- (32.07 KiB) Downloaded 401 times
Forum now shows full link URLs thanks to https://www.phpbb.com/customise/db/extension/full_links/
Forum now allows to paste images directly from clipboard instead of attaching files.
Why? WHY HAS NO ONE EXPLICITLY ASKED FOR THIS UNTIL TODAY?!
Please consider reminding me of anything else this forum instance is missing.
I guess I should mention,
-- When on my Android phone, using Chrome, when I browse to a forum there is a link for "Board index" at the top and bottom of the thread. The link at the top always works, the one at the bottom works like 50% of the time. It seems longer thread are more likely to fail. I usually just stroll to the top and click the one at the top of the page. Also I've only see this on my phone.
-- Again on the phone, when I click the search feature it formats way off to the right.
Not really a big deal, I just deal with them. But since you are poking about why people are not making requests.....
I've just disabled .ini and .msq attachments since https://rusefi.com/online is really the way for those.
Just removed 29 signature spammers with https://www.phpbb.com/community/viewtopic.php?f=456&t=2401101 help
