[info] electronic throttle body control ETB
960 wrote:
Thu May 02, 2019 8:05 pm
Are you getting same or different results with the 7209?
Pretty different results on 7209 so far. With 7209 I've used two wire control, and duty cycles and behavior overall is pretty different. On my TODO list is to run 7209 with three-wire control same as I use on VNH2SP30.
At the moment focusing on VNH2SP30 since it works better, at the moment the focus is learning how to tune PID and establishing a better base line. Once VNH2SP30 is great, will try to repeat same on 7209.
I guess I've suggested a few times to build a bench setup a few times already? :)
960
Post by 960 »
If they require different values there is something wrong.
Have you measured if the output seems right?
I am measuring a little now, and with 300 HZ I have 233 out
With 500 set, I have 388 out
With 200 set, I had around 158 out
960 wrote:
Sat May 04, 2019 6:06 pm
Since we have a webcam in your garage, we all know exactly what you measured, how you did it and using what hardware! We can even see which board with what stm32 chip! Because all chips are the same and no details were left behind.
I am sarcastically trying to say that you leave a LOT to be guessed. If you feel like chatting let's do that at https://rusefi.slack.com/messages/CF6F16278/details/
Please get a VNH2SP30 board from eBay so that you can compare. Frequency could be screwed for too many reasons. I have no osc and no brains to use it anyway.
960
Post by 960 »
russian wrote:
Sat May 04, 2019 6:46 pm
You know exactly what hardware and MCU I use.
Look at your own posts, do you tell what hardware you are using in each of them?
fair point :) i always use F407 at 168 mhz thats the most proven platform. F407@168 is definitely rusEfi default. I also know that you alternate between F4 and F7. i am very worried about your usage of F7 since it gives me only problems while currently not providing any additional value.
please confirm that you are using f407@168mhz for ETB research.
960
Post by 960 »
russian wrote:
Sat May 04, 2019 7:26 pm
I told you in a earlier post that I have a F7 at this board, and dont want to swap more times.
My new boards are ordered, so maybe then. I also asked you in the earlier post how the software PWM are calculated, and if it's affected by MCU speed.
I have measured the PWM from the TLE7209 today, and the results dont match.
It's measred across pins.
If it was based on the MCU speed( My MCU are 216Mhz), like scaling, I would expect it to be too high, not to low.
EDIT:
After calculating the results against the MCU speeds, it matches the wrong way.
388Hz out with 500Hz set in TS = 28%
216Mhz VS 168Mhz = 28 %
Here we start at P=6, I=D=offset=0 and increment P by 4. Running the same test and finding lowest magic number.
So far P=22, I=D=offset=0 is the best result, using the same curve as above.
"Coolant" is ETB temperature.
mk e
Post by mk e »
The standard answer to optimize a P only system is increase P until the system oscillates then dived by 2......but P only doesn't seem like the best choice for a throttle and certainly did not produce the best results on my setup.
OMG Mercedes used to have mechanical cable from pedal to engine bay and pedal sensor in engine bay and ETB!
Looks like this was used on some US models like maybe 2003 Mercedes Benz CLK 320 Gas Accelerator Pedal Position Sensor A012-542-3317.
Honda had something similar 37971-RBB-003
New feature: (Pedal, RPM) > desired TPS position table
https://github.com/rusefi/rusefi/issues/835
Untested unfortunately, I might try this in about a month from now.
mk e
Post by mk e »
russian wrote:
Sat Jun 15, 2019 6:37 pm
I like it. I just did a 1D table in mine, pedal to desired TPS so it works like a simple cam but I really like the rpm addition thought. I thought about doing something 2D with gear selection but haven't gotten to it...and not sure its any better than your rpm choice.
Good find on the remote pedal sensors too. I think I posted earlier in the thread I have a ...96? 911 sensor that is I think 1 year only and similar, it was the only one I knew about but it seems several companies had the same issue as technology changed faster than body designs.
i guess, the next feature request would be cruise control (at least for manual transmission, no fancy automatic gearbox control).
mk e
Post by mk e »
puff wrote:
Mon Jun 17, 2019 7:31 pm
Safety wise that would need a bit of thought.....letting the computer not just follow the driver commands but open the throttle as it sees fit will want a bit of caution baked in I'd think.
I don't see much difference between controlling the throttle position based on the pedal sensor readings and controlling the throttle position based on vehicle speed sensor readings. Yes, that would require additional sensors on a clutch and brake pedals plus some controls to set up and display desired speed. May be some additional safety algorithm preventing rapid changes in speed. But that shouldn't be difficult?
mk e
Post by mk e »
You're right, its not much different....just more layers and more opportunity for things to go wrong. i'm told the OEM do all this stuff redundantly with completely separate variables and memory locations then make sure the results match, then move the throttle or maybe more accurately allow the throttle to continue to operate. On my BWM the speedometer is working fine and the computer is calculating fuel mileage, miles remaining in the tank , average speed, etc. so the computer knows how fast and fast the car is/has gone but cruise, traction control, ABS, 4x4 are all off-line because the computer isn't happy with some of the wheel speed sensor data. For sure my VWs would close the throttle if the throttle and brake were both proessed for more than about 5 seconds....
OEMs do lots of stuff like that to get what they consider acceptable risk....after market...well.....the wiring the manufacture specified for my ECU used an ECU output to control the main ECU power to allow things inside the ecu to shut down in an orderly way and makes it possible to do things like long term trims being written to flash and prevent any chance of a coil firing before the ecu was fully booted I was told.....then one day I realized my ecu had partly locked up and was ignoring the key-off signal and was not shutting anything down, divide by zero error, it hates that it turns out and reacted by ignoring the ignition off signal. WTF!!!! I rewired to add a safety relay that lets the ecu shut itself down but the coils and injectors are frikin off when the key is off and I know the the driver has the power to shut down a misbehaving system. That solution would not meet OEM specs but at least I feel safe enough now.
Just something to keep in mind I think.
so where we stopped gentlemens ?
which chip or PCB need to use ?
TLE7209 or VNH2SP30 ?
960
Post by 960 »
Abricos wrote:
Thu Jul 11, 2019 1:22 am
It actually works quite good now.
I use TLE7209, but I think there are support for others like TLE9201SG.
960 wrote:
Thu Jul 11, 2019 1:33 am
let's assume i have a chip TLE7209
what do i need to do next ???
960
Post by 960 »
You need to connect Dir1 and dir2 to MCU.
Select pins in TS, and use the settings in menu
Set Dis pin Low with resistor, En pin high with resistor.
You can find my schematic for it in microrusefi folder
OrchardPerformance
Post by OrchardPerformance »
I can also confirm the VNH2SP30 works quite well as a low cost, easily available option. Had no trouble running throttles from 40-70mm on the bench with it.
Preferred is the OEM style chips but the VNH2SP30 will do the job.
Crazy Striker
kit assembler
Post by Crazy Striker »
Hi guys, sorry to revive this with my issues but I need your advices ;)
I will need a second throttle body for my Miata with the supercharger to deal with idle issues and everything.
My plan was to let the stock one in place and use a E46 Bosch ETB (14£ off eBay) to choke the charger and avoid the unbearable noise.
Does it seem a viable option to you, can I retain the stock tps ans use it as a sender for my tps commande, as well as designing a custom curve for the relationship between TPS and ETB position to smoothen boost activation and eventually limit power for my emissions tester.
VNH2SP30 seem a good and cheap idea for interfacing with my frankenso as well.
Thanks guys
Gwendal
Please post same exact thing in your vehicle topic and let's continue there? This is on the edge of what this topic here is for in my opinion.
I think I know what you are looking for and I think it would work. A picture or a drawing would help just to reduce the chance of misunderstanding :)
Crazy Striker wrote:
Mon Aug 19, 2019 5:07 pm
The down side of VNH2SP30 is that it requires three 5v control lines, not 3v from stm32 pins - but you probably have three channels of high-side to use with VNH2SP30 so you are good.
Now with MRE board
This chip from eBay has undocumented self-ventilation and self dis-soldering features! Maybe I might have wired things wrong :)
We now have dual ETB/DBW support :)
Very limited documentation added to https://github.com/rusefi/rusefi/wiki/HOWTO_electronic_throttle_body - this really needs a lot of improvement.
Here's another way to run two throttle bodies
Tire guy
Post by Tire guy »
That's awesome, I never seen a CAN driven ETB, must be first :o
duhafnusa4
Post by duhafnusa4 »
Where do i get the TLE7209 board? Or am i being dumb and it's integrated in my micro mre board?
duhafnusa4 wrote:
Fri Apr 10, 2020 2:56 am
microRusEfi board has a smaller/newer TLE chip on board, sounds like you do not need a TLE7209 board.
