[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) GCC/ARM compiler issues? - rusefi.com
What's the word on the street on GCC for ARM compiler reliability? Are any versions better then?
I was chasing this red LED/fatal firmware error and it really looks like it is only reproducible with binaries created on the build server?! The build server - http://crapcan-am.com:8080/job/rusEfi/lastBuild/console - currently has
gcc version 4.8.3 20131129 (release) [ARM/embedded-4_8-branch revision 205641] (GNU Tools for ARM Embedded Processors)
Speaking of which, what are we using on the build server? On Windows the GCC/arm compiler I am using is from Sourcery CodeBench Lite Edition, are there any other options on Windows?
I am totally confused by a number of different (?) yet all GCC (?) compilers.
I think this became wrong because we changed gcc options to hard fp but not to tell g++ about this.
locally i fix it in 3.0 port so it was works for me.
i'll try it in an hour or so.
what this mess is all about? just to make our build server compile proper images, the same as iar? or make all compilers lead to the same stable result?
puff wrote:what this mess is all about? make all compilers lead to the same stable result?
We never know where the bug is. If the bug is in the compiler used on the unix build server it's one thing, but it very well be that GCC on the build server is fine but we have an issue somewhere which is only visible under this particular version of the compiler - could be that some compilers are masking the issue and some are not. So, it's worth checking if we own this problem, not anyone else.
The issue that c++ code was not using FPU while c code was could very well be that issue on our side which was masked by all compilers but 4.8.3
okay. launched 3916 not_sure version - so far works fine (but for the minor glitch with displaying rpm change in devconsole: its not updated for some reason if the delta is smaller than 50 rpm?) - inj duration is fixed, got some readings in analogue sniffer. will leave it working for some time.
Looks like the root cause of the issue we were having while using the whatever version of the compiler installed on the unix build server was about using hardware FPU by the C compiler and using software floating point by C++ compiler. Thank you @ for fixing the Makefile, now both C and C++ are using the FPU and this seems to have resolved the issue!
