3D printing ECU case - cost?
ecologicalleds
Re: 3D printing ECU case - cost?
Post by ecologicalleds »
I have a 1170mm x 2450mm X 200mm cut path cnc router I have learned how to cut 6061 aluminum with down to .01mm resolution. (still learning the differences from cutting wood to aluminum) I don't know if that will help or not.. Willing to experiment, practice. lol.
Plastic injection or vacuum forming, could possibly make the die plates also.
ecologicalleds wrote:I have a 1170mm x 2450mm X 200mm cut path cnc router I have learned how to cut 6061 aluminum with down to .01mm resolution. (still learning the differences from cutting wood to aluminum) I don't know if that will help or not.. Willing to experiment, practice. lol.
You need to warn me, not safe for work. I started humping my desk :)
I like the orange. Good and safe in the fall hunting season.
Post by stefanst »
So,
you're saying I need to get my trusty old Mendel out of storage?
Sweet, I see programming device and all.
Rhinoman
Post by Rhinoman »
Black plastic cases usually contain more carbon than other colours and are more effective at screening although you won't get anywhere near the same attenuation as with metal. Most of the ECUs that I deal with have had black plastic cases since around 2001. I would prefer to have an aftermarket ECU in a metal case because they don't tend to be designed for low noise.
Rhinoman wrote:I would prefer to have an aftermarket ECU in a metal case because they don't tend to be designed for low noise.
Right now I am trying the hybrid approach - metal side walls and back cover, plastic top cover for usability. I guess metal top cover should also be included in the bundle.
There's one more issue to consider: dew point for metal walls.
BTW, as an option - there is a sticky aluminum foil tape, which could probably be used as a metal shield.
darxfame
Post by darxfame »
Can you printing case for prometeus ecu? What does it cost $?
darxfame wrote:Can you printing case for prometeus ecu? What does it cost $?
I don't have answer ...
Спорный вопрос ...
И для франки это прототип это не будет серийно делается на 3д принтере ... дороговато ...
darxfame
Post by darxfame »
Спорный вопрос ...
Таки прямо дороговато? Ни у кого своего принтера нет?
Спорный вопрос ...
А давайте обсудим ...
http://rusefi.com/forum/viewtopic.php?f=8&t=1229
RadMx5
Post by RadMx5 »
russian have you got a DXF file for the top lead you 3D printed if so ho well it fits??
I'm planning to make the top lead of my ECU of clear plastic milled on CNC.
RadMx5 wrote:russian have you got a DXF file for the top lead you 3D printed if so ho well it fits??
Yes I have ... it's not 100% finished ...maybe 90% ...
https://tinkercad.com/things/4jUUNit87a1
Or I made new style https://rusefi.com/forum/viewtopic.php?f=3&t=699&start=60
I would say, milling plastic (rather than extruding it) allows for finer clearance. Why not taking a measuring caliper and building your own model? btw, what sort of plastic you plan to use?
V8Volvo245
Post by V8Volvo245 »
Probably a stupid question, but wouldn't the ecu need a plastic lid if it's going to have Bluetooth communication?
RF would need to leak out some now, some options include remote mount the Bluetooth, plastic lid, hole in sheet-metal, etc. The RF hole would need to be around 5in (12.5CM)
https://www.google.com/search?q=2.4ghz+wavelength+in+mm
V8Volvo245
Does the cover have to be 3d printed? Can it not be 2D and laser cut?
There are several covers noted here. I think you mean the Frankenso lid. It could likely be laser cut. I seem to recall the plastic above the STM32 Discovery board is thinner, such that you can see the blinking LED's below. as well I recall the 3D printed one includes the counter sinks on the screws such that you can use the OEM screws. If you laser cut you might want to keep those blinking LED's in mind, and you'll either need to add the counter sinks after the laser operation, or change to a different screw.
960 wrote:I dont see any issues with my Ender 3 Pro yet.
I put it together and had it up and running in about a hour or two.
Now it has been running 24/7 unattended for a couple of weeks, and still not one single issue.
I scrape off the glass-plate and check the leveling between each print.
(It's just a 2 minute job anyway)
In the start, it was a little off, but lately it have stayed leveled.
I just spray a thin layer of hair-spray, and it-s ready to go.
(No cleaning)
ZHoob2004 wrote:prusa i3 is a good option with higher quality control
https://hackaday.com/2016/07/06/build-a-3d-printer-workhorse/
https://www.thingiverse.com/thing:100128
960
Post by 960 »
All parts printed and fits nice together.
The downsize are not the cost, but the time it takes..
mck1117 wrote:
Mon Nov 02, 2020 7:42 pm
I will have a Prusa Mini in approx 2-3 week
MIN-KIT-ORG-PEI
Total products $349.00 Total shipping $49.07 ? Looking forward to learn how it went!
Tue Nov 10, 2020 11:50 pm
MIN-KIT-ORG-PEI
I also got some PETG filament and a 0.6mm nozzle, so it was a little more than that, but we'll see how the $400 Proteus Case Machine does!
mck1117 wrote:
Tue Nov 10, 2020 11:52 pm
How did it go?
How many hours before opening box and first not messed up print?
How many prints were messed up until you got a happy Proteus print?
How long does it take to print Proteus case, both top and bottom?
