No jumper pin:
Dev console works fine.
TS - Says "Invalid data recieved from controller"
Dev Console says:
2014-12-06 16_28: EngineState: TunerStudio: invalid size: 32768
2014-12-06 16_28: EngineState: ERROR: size
2014-12-06 16_28: EngineState: TS RX on PC11/TX on PC10 @38400
2014-12-06 16_28: EngineState: TunerStudio total/error counter=95/72 H=0 / O counter=0 size=116 / P=0 / B=0
2014-12-06 16_28: EngineState: TunerStudio W counter=0 / C = 0 / P = 0 / current page 0
2014-12-06 16_28: EngineState: page size=10008
2014-12-06 16_28: EngineState: le_formulas 6280
2014-12-06 16_28: EngineState: crankingCycleBins 9600
2014-12-06 16_28: EngineState: engineCycle 344
Using the jumper pin:
Devl console works fine: I get the whole shebang from message one.
TS works fine:
What's broken: ADC values are wrong, TPS is fixed at 70something and the WBO chanel does not respond. I verified this on the bench by grounding the WBO channel. No reaction while console switch is active, goes to 0 under normal operation. This starts hapening after i reboot the board with the jumper, not when i install the jumper.
Was hoping to tune the engine today, can't do it if i don't get reliable AFR's.
