KICAD
Re: KICAD
kb1gtt wrote:
Sat Jan 19, 2019 10:56 am
I have posted my repo for now. This will be merged with the official repo when @russian gets a minute to merge. Once that happens, I'll update the below link.
https://sourceforge.net/p/daecu/code/HEAD/tree/Hardware/trunk/rusefi.com/rusefi_lib/BOM_related/
Finally I kind of understand this and same is now available at https://github.com/rusefi/kicad-libraries/tree/master/BOM_related
Re: KICAD
Here are some notes about how I merged two kicad projects (both schematics and PCB) in KC5.
-- Copy one project as a startting point, AKA PT2000 --> TestMergeProject
-- Delete extra files, .csv, gerbers, .net, etc. Modify files like knownissues.txt
-- Rename core files AKA Common_Rail_PT2000.XXX --> TestMergeProject.XXX core files are .pro .sch .pcb
-- Open reference Breakout_88pin_VAG-Connector.pro, get symbul and footprint lib information
-- Re-annotate starting with 1000, so that you do not have any conflicting refdes in this vs the merged files.
-- Open TestMergeProject.pro.
-- Add symbol libs link per reference schematic.
-- Add footprint libs link per reference layout.
-- Open schematic, move everything off the right side of the border. Save and Close.
-- With generic text editor like notpad++ open Bosch_88pin_Breakout.sch then copy everything below
Comment4 ""
$EndDescr
And above
$EndSCHEMATC
-- With text editor, open TestMergeProject.sch, go to the end of file, and befor the last line paste the above copied stuff.
-- Open TestMergeProject.sch schematic via KICAD launcher, it should open with no issues. Fix any issues it has.
-- Make any connections you need to make. In this example the GND was the only connection between the two boards.
-- open PCBNew, Not from KICAD, but manually open TestMergeProject.pcb with PCBNew. This will allow the "append" option. C:\Program Files\KiCad\bin\pcbnew.exe
-- Move existing layout off the right side of the border
-- File append Bosch_88pin_Breakout.pcb
-- File save
-- File exit or get out of this PCB file.
-- Open TestMergeProject.pcb PCBNew with KICAD laucher.
-- Run DRC, which will reflood, etc.
Once it works, you can change the refdes and update the layout as required. AKA change 1000 above back to something like 10.
Re: KICAD
KiCad 6 with official Altium import is 2-6+ months away
"early 2021" 3 months ago
"mid 2021" 11 days ago
I wonder how long it would be in that "6 months away" phase :)
Re: KICAD
Actually RC1 https://gitlab.com/groups/kicad/code/-/epics/16 currently says "end of February"
Re: KICAD
Re: KICAD
Look nighties use 6.0 not 5.99 as recently!
Re: KICAD
And they have officially released it!
https://www.kicad.org/blog/2021/12/KiCad-6.0.0-Release/
Re: KICAD
you mean version 7.0.0?
"KiCad 6.0.* will no longer be maintained"
Re: KICAD
puff wrote:
Mon Feb 13, 2023 11:54 am
And Matt has migrated WBO stuff from 5 to 6 like a week ago lol.
Re: KICAD
Current Version: 8.0.1 Well, we got older.
